Thread: General Properties on Tool Palette tools not sticky
    2005-06
    21
    Default General Properties on Tool Palette tools not sticky
    I have a dimension tool on a tool palette with properties that put the dimension on the dimension layer and set color ByLayer. Half the time it puts the dimension on the current layer anyway. This happened about 1/3 of the time in AutoCAD 2018. It seems to be happening more often in 2019. Is there anyway to fix this? This happens with other tools as well.
    Dennis
    2009-11
    5,714
    Default Re: General Properties on Tool Palette tools not sticky
    What is DIMLAYER sysvar set to?
    Computer Specs:
    2005-06
    21
    use current
    2009-11
    5,714
    Well, I've just tried to replicate the behavior in your OP using 2019... and everything is working correctly for me.
    When DIMLAYER == "Use Current" my Tool Palette dimensions come out on the Tool Palette specified layer, and when I change DIMLAYER to an actual layer (not the same as my Tool Palette specified layer), it then overrides it, as it should.
    Cheers
    Computer Specs:
  1. 2014: can't create new tool palette tools
    By bjm in forum ACA General
    Last Post: 2014-03-07, 06:07 PM
  2. General tool properties
    By Liamnacuac in forum AMEP General
    Last Post: 2009-11-13, 10:24 PM
  3. Ribbon Customization for Tool Palette Tools
    By adafchik in forum AutoCAD CUI Menus
    Last Post: 2009-10-06, 03:35 PM
  4. Tool Palette customizing, custom tools, and the image
    By Maverick91 in forum AutoCAD General
    Last Post: 2007-10-31, 07:35 PM
  5. Properties palette displays only the general properties ??
    By mengseng in forum AutoCAD General
    Last Post: 2004-08-25, 08:16 AM
Tags for this Thread
