Thread: 3D Polyline Custom Linetype Display
    2018-02
    Question 3D Polyline Custom Linetype Display
    Hello everyone,
    We created a linetype with the letter E in it for an electrical line --E--
    We cannot get 3D polylines to display this properly in Paperspace.
    It does display properly if we change the 3D Polyline to a Feature Line in Civil 3D.
    Is there a setting to make this happen without making it a Feature Line?
    Thanks
    Bill
    2015-05
    West Des Moines
    253
    Default Re: 3D Polyline Custom Linetype Display
    You need to clarify what the issue is. Is it not displaying properly or is it not displaying at all like a continuous linetype?
    I've seen squished linetypes (with 3D polylines I believe) which I know was elevation related as the line followed the elevations between points and drew in a bad way. If that's the case you'd have to flatten your lines to smooth it out.
    If it's just a solid line run the linetype3dplineon command and it should turn on.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    3,078
    A 3D Polyline cannot display linetypes. Civil 3D Feature Lines are not the same thing.
    https://knowledge.autodesk.com/suppo...e-setting.html
    Tom Beauford P.S.M. - Civil 2019 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    2015-05
    West Des Moines
    253
    I don't know when they introduced the linetype3dplineon/linetype3dplineoff commands, but 2016 and above have it.
    Edit: I did do some looking into though, I think it was just regular lines that I saw the issue with in the past though.
  1. LISP that Add's Polyline Lengths by Linetype
    By jdimi8392 in forum AutoLISP
    Last Post: 2017-12-18, 06:08 PM
  2. Custom Linetype
    By engineering.158616 in forum AutoCAD General
    Last Post: 2010-11-08, 03:59 PM
  3. single polyline & multiple linetype
    By lalit_jangid in forum AutoCAD Mechanical - General
    Last Post: 2009-06-01, 07:44 PM
  4. Custom Linetype Needs
    By crystalp in forum AutoCAD General
    Last Post: 2008-04-02, 09:13 PM
  5. Extract Linetype information from a custom Linetype
    By H.Hunter in forum AutoCAD Customization
    Last Post: 2006-08-15, 05:27 AM
Tags for this Thread
