Results 1 to 1 of 1
Thread: Alignment revision issue with Surface points created from Grading Objects
    2009-11
    Raleigh, NC
    700
    Default Alignment revision issue with Surface points created from Grading Objects
    I have created an existing & proposed surface. Any grip edit revisions to an alignment is causing the feature line from the grading object that ties to the existing surface to generate multiple new points (surface points) on elevation zero. the Alignments are not outside of the proposed boundary which I have discovered causes this same issue. Any suggestions or resolutions?
  1. 2017: Grading surface tries to attach to an alignment line when grading done first, why? How to fix?
    By tadthurston725387 in forum AutoCAD Civil 3D - General
    Last Post: 2018-07-19, 05:46 PM
  2. 2009: Create Points from Surface along an Alignment
    By JeffClark in forum AutoCAD Land Desktop - General
    Last Post: 2016-03-17, 08:57 PM
  3. 2014: Divided Surface Alignment Issue (to Adjacent Divided Surfaces)
    By TAmtb11 in forum Revit Architecture - General
    Last Post: 2013-11-15, 03:00 PM
  4. 2012: How to create points on LHS alignment which are at even chainage w.r.t the main centreline alignment
    By gary.chan.kc355500 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2013-04-25, 07:25 PM
  5. Weeding feature lines created from grading objects
    By gjschaap in forum AutoCAD Civil 3D - Grading
    Last Post: 2009-04-01, 10:41 PM
