Thread: Description Key / point markers oriented to alignment
    Question Description Key / point markers oriented to alignment
    Civil 3D 2017. Looking for help to orient description key/point marker blocks to alignment. For example I have several road signs located along a road alignment and use a "T" as symbol block. Trying to figure out how to orient the leg of the "T" parallel with my centerline alignment?
    2015-05
    West Des Moines
    253
    Default Re: Description Key / point markers oriented to alignment
    Sounds like you want to rotate the point marker to make it look more realistic? That's done with the marker rotation on the point. Just select it and look for it at the bottom of your properties.
    Was hoping to be able to simply set the point marker orientation relative to the centerline rather than editing rotation for each point individually. Idealy in the Point Style however the only options for Orientation reference that I can see are "Object", "View" & "WCS". Am wondering of there is a way to add the defined centerline as a "4th" orientation reference or some other relatively automatic option to editing each point individually.
    2015-05
    West Des Moines
    253
    Ah, yeah I'm not sure if that can be automated. It it's doable people smarter than me are going to have to explain how to do so.
  1. 2009: Create a Selection set from Civil 3D point group or point description.
    By sdrewinc432892 in forum AutoCAD Civil 3D - General
    Last Post: 2016-08-05, 07:01 PM
  2. Replies: 2
    Last Post: 2012-04-24, 05:44 PM
  3. Point Markers do not plot when xrefed
    By alarism in forum AutoCAD Civil 3D - Survey
    Last Post: 2011-05-24, 09:04 PM
  4. Dynamic Blocks and Point Markers
    By Lisa Marie in forum AutoCAD Civil 3D - General
    Last Post: 2009-01-22, 02:51 PM
  5. Vertical Alignment - PVI Markers
    By brent.77436 in forum Land Desktop - General
    Last Post: 2005-08-12, 01:40 PM
