Thread: The following views could not be published.
    2018-12
    Default The following views could not be published.
    HI all,
    while exporting to CAD, i am facing the issues, i am not able to export from Revit 2019 to CAD
    please help me ,
    Adarsh
    Digital Delivery Director Brian Myers's Avatar
    2003-02
    Stillwater, Oklahoma
    1,819
    Default Re: The following views could not be published.
    Could you provide a bit more information? Which views can not be exported? Do they contain modeled objects? I've seen this occur before with views that specifically contained linked in data in a view and could not be exported because technically there was no information to export in a form Revit could easily interpret.
    2016-07
    H all,
    I am also unable to export Revit (2019) sheet filr to CAD.? There is 10 no. of sheet file, when i start exporting file that time only one file i can export. for other file i need to close revit and open, again sync. then export. for every file i need to close and open. any solution for this issue.?
  1. How to get an AutoCAD book published?
    By tfulmer in forum Training
    Last Post: 2008-07-08, 03:31 AM
  2. Published plots are mostly blank
    By kristow4 in forum AutoCAD Plotting
    Last Post: 2008-05-01, 09:33 PM
  3. Image Published to DWF Does Not Plot
    By jmorgan in forum AutoCAD Plotting
    Last Post: 2006-04-11, 11:24 PM
