Thread: Ceiling Phases
    2012-02
    Default Ceiling Phases
    I want to show Demo. Ceiling in Demo. RCP, but only the outlines of the ceiling turns to demo. dash lines and ceiling grids are showing solid line. How can I make all lines become dash in my demo. reflected ceiling plan?
    2001-12
    Irvine, CA
    7,444
    Default Re: Ceiling Phases
    Ceilings use a surface pattern to show the grid. The demolition state and graphic overrides does not alter the surface pattern assigned to ceilings. It's a long standing situation unfortunately. The typical solution is to use a separate ceiling type for those that are to be demolished and use a different surface pattern that uses a dash pattern for the grid lines. You can find a useable pattern at RevitCity for example.
  1. Unable to see Symboles in Ceiling Plan on Sloped Ceiling
    By plavallee in forum Revit MEP - General
    Last Post: 2011-06-10, 02:58 AM
  2. Revit Face Based Ceiling Components in Ceiling hosted incorrectly
    By jkhmiller in forum Revit MEP - General
    Last Post: 2009-11-03, 03:50 PM
  3. Ceiling Based Families Moving with the Ceiling
    By NKramer in forum Revit Architecture - Families
    Last Post: 2008-06-25, 04:38 PM
  4. Ceiling hosted objects deleted when editing ceiling
    By mzabritski in forum Revit Architecture - General
    Last Post: 2008-06-25, 03:58 PM
  5. Matching ceiling grid to ceiling rendering
    By Nevine in forum Revit Architecture - General
    Last Post: 2004-11-27, 06:55 AM
