Thread: Door Panel Type Instance, Schedule Type Mark
    2019-01
    Default Door Panel Type Instance, Schedule Type Mark
    I have a door family that has an integer instance parameter that controls the "door panel type" where "1" equals a flush panel, "2" equals half lite, "3" equals Full lite etc.
    I'm trying to tie either a text parameter or a perhaps another integer parameter to the "door panel type" where if you change the instance parameter "door panel type" it will output "A", "B", or "C" to a scheduled shared parameter which these letters correspond with my door panel type legend where an "A" is a flush panel, "B" is a half lite, "C" is a full lite etc.
    This is my setup so far
    Any helpful input would be really appreciated, thank you!
    -Steven
    2003-03
    Philadelphia, PA
    2,370
    Default Re: Door Panel Type Instance, Schedule Type Mark
    Add a formula to the Panel Type Mark parameter:
    if(Panel Type = 0, "A", if(Panel Type = 1, "B", "C"))
    That will set the Panel Type Mark parameter to "A" if Panel Type is set to 0, "B" if set to 1 and "C" if set to any other value. You can nest additional if statements if you have more than three types. If you want to show "C" only if Panel Type is 2, then something like the following could be done:
    if(Panel Type = 0, "A", if(Panel Type = 1, "B", if(Panel Type = 2, "C", "ERROR")))
    David Koch
  1. 2013: Door Schedule - Panel Type and Frame Type
    By jboersema in forum Revit Architecture - General
    Last Post: 2018-09-04, 01:30 PM
  2. 2016: SCHEDULE NESTED SHARED PANEL FAMILY TYPE IN HOSTED DOOR ROW
    By aheitzman79 in forum Revit Architecture - General
    Last Post: 2018-08-28, 07:52 PM
  3. Can I delete Type Mark Parameter from a Door?
    By billy007nh in forum Revit Architecture - Families
    Last Post: 2011-07-27, 05:22 PM
  4. Changing type mark in Door tag
    By theshell07 in forum Revit Architecture - Families
    Last Post: 2010-08-30, 05:25 PM
  5. Door families: Instance or type parameters
    By tim.101799 in forum Revit Architecture - Families
    Last Post: 2006-02-02, 02:02 PM
Tags for this Thread
