The attached image is of a single cul-de-sac region. This one is generating a long handle which seems to originate from the radius point. Has anyone seen this type of glitch, and do you have any suggestions to correct it?
Thanks in advance.
Thanks in advance.
Image??
Check the geometry of the objects being used to define the cul-de-sac in the corridor. Without an image I can only suspect the centerline alignment isn't exactly at the radius point
