Ok, here's the issue.
I have several pipe profiles created with C3D-2016, and when I run a "Publish" on the sheets (to pdf, and it doesn't seem to matter how the publish is run), the fittings on the profiles will 'extend' to the edges of the profile view. When I run a 'Print' (same plot settings, BTW) on each sheet individually, the sheet output is correct.
Is this an issue with the printing, or with the pipe settings?
attached are two snippet views of the issue.
without the lines: wo_lines.PNG
with the lines: w_lines.PNG
