Thread: moving section views
    2004-06
    Slidell, Louisiana
    972
    Default moving section views
    I have two section views. I annotated some points in the view with a civil 3d label. i need to move them closer together, but
    when i select them with a window and move one, the annotation does not go with it. what am i doing wrong or what is the proper
    procedure to move them.
    2015-10
    Central New Jersey
    439
    Default Re: moving section views
    Move just the view, regen and the labels should move the the new location of the view?
    2004-06
    Slidell, Louisiana
    972
    that's what i thought too but that didn't work. also the elevation changed.
    i also selected the label thinking there would be a reset option, wasn't there.
    edit: i jumped the gun. yes MMccall, by just selecting the view and then move worked. i was windowing everything before.
    thanks for solving my issue
  1. Section Views, fix the seperation and vizability across plan views
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2012-07-24, 02:46 PM
  2. 2011: Creating, or Updating Section Views from 3D Piping to a 2D Section
    By Drafter1981 in forum AutoCAD 3D (2007 and above)
    Last Post: 2011-11-23, 11:46 AM
  3. Pipe network structions to show structure section in section views
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2010-10-06, 01:04 AM
  4. Section Marks Moving in Dependant Views
    By Dwane Lindsey in forum Revit Structure - General
    Last Post: 2007-10-06, 05:15 AM
  5. Section Marks moving in Dependant Views
    By Dwane Lindsey in forum Revit Architecture - General
    Last Post: 2007-10-05, 04:44 PM
