Thread: Dynamic Block - Glass wall and door
    2018-11
    Default Dynamic Block - Glass wall and door
    Hi everyone!
    It's my first post here so be kind with me!
    I'm good with dynamic block (general base!) but I have a problem with one that I'm trying to do. I have a dynamic block for architectural glass wall with a door.
    I managed to have one visibility state that shows the door, a glass wall and a little section of glass wall in 45°. The door, the glass wall, the section in 45° and the wall thickness can stretch. I would like to be able to flip all the block and only the small section of glass wall in 45°. So this is where it gets confusing. I did the flip for all the block but my problem is when I flip only the small section. If I do so, when I stretch the wall thickness, it doesn't follow because it is like backwards. I have attached the block. Sorry in advance, the visibility states are in French!
    Can a kind expert in dynamic block can help me please?!
    Thank you
    Stephanie
    2011-10
    Norfolk England
    57
    Default Re: Dynamic Block - Glass wall and door
    Hi
    The geometry of your framework do not seem to line up so the 'flipping' flip states are flipping along different 'flipping' axis
    Try lining up the framework and see how that goes.
    Cheers
    2020-03
    I'm from Quebec. I have been here for 4 months and built my new home in Quebec. I decided to put a glass partition wall in my kitchen and searched for many glass manufacturer. But most of the products are not having good quality. One of my colleagues suggested me gsmglass.ca. Has anyone experience this? I would like to have your suggestions as soon as possible.
  1. 2016: door for Curtain wall, single glass
    By Bluefairy in forum Revit Architecture - General
    Last Post: 2015-08-27, 03:40 PM
  2. 2016: dynamic block to write automatically door width value and door type accordingly.
    By architurk in forum Dynamic Blocks - Technical
    Last Post: 2015-08-24, 09:14 PM
  3. Anyone have a glass block wall?
    By rkc in forum ACA General
    Last Post: 2007-06-01, 03:27 PM
  4. Dynamic Block door, update text automatically as door is changed
    By Matt Mercer in forum Dynamic Blocks - Technical
    Last Post: 2007-02-05, 01:41 PM
  5. howto create a glass wall with a glass door
    By Dave Lewis in forum Revit Architecture - General
    Last Post: 2007-01-22, 07:49 PM
