Results 1 to 1 of 1
Thread: Walls not appearing in DWG export
    2018-01
    Default Walls not appearing in DWG export
    Hi,
    Was wondering if anyone here has encountered the same issue and found a resolution to it.
    I'm exporting a drawing to DWG and random walls are not appearing in the export. When I do wireframe display, the walls appear, however - the overall drawing does not look correct. Is there a way to maintain the hidden line view and ensure walls do not drop off in the export?
    2 walls are next to each other - one appears, the other doesnt.
    Thanks!
  1. 2013: Volume in Schedules appearing and not appearing
    By Chris.Partin in forum Revit Structure - General
    Last Post: 2013-02-20, 04:19 PM
  2. Revit Export Setup - Walls
    By Twolly in forum Revit Architecture - Families
    Last Post: 2012-12-11, 01:37 PM
  3. 2012: Export to cxl then some beams and all walls went missing.
    By JMY in forum Revit Structure - General
    Last Post: 2012-11-28, 09:08 AM
  4. 2012: Walls of Linked Revit Not Appearing
    By crosado115217 in forum Revit Structure - General
    Last Post: 2012-07-05, 03:25 PM
  5. Export with Links -No Walls
    By John Anderson in forum Revit Architecture - General
    Last Post: 2007-05-07, 05:56 PM
