Thread: Select all objects in current workspace
    2001-03
    ROMANIA
    24
    Default Select all objects in current workspace
    Using VLisp, I want to make a selection set that contains all the objects in the current workspace.
    I do not know how to set one of the vlax-safearray-fill function arguments to exclude from the selection the objects on layers Freeze, Off and Lock.
    (setq ACDC (vla-get-activedocument (vlax-get-acad-object)))
    (vlax-for
     Obj
     (vla-get-layers ACDC)
     (if (or ;;Filter layers locked, frozen or off
       (eq (vla-get-freeze  Obj) :vlax-true)
       (eq (vla-get-lock    Obj) :vlax-true)
       (eq (vla-get-layeron Obj) :vlax-false)
    ;;   (setq L_FILTER (append (list (vla-get-name Obj)) L_FILTER)) ;;Layer list
      (setq L_FILTER (append (list (list (vla-get-name Obj))) L_FILTER)) ;;Layer list of lists
    (setq SS_ALLO (vla-add (vla-get-selectionsets ACDC) (itoa (getvar "MILLISECS")))
      F_CODE (vlax-make-safearray vlax-vbinteger (quote (0 . 1)))
      F_VALE (vlax-make-safearray vlax-vbvariant (cons 0 (1- (length L_FITER))))
    (vlax-safearray-fill F_CODE (quote (8 410)))
    (vlax-safearray-fill F_VALE  (list what_to_write_here? (getvar "CTAB")))
    (vla-select SS_ALLO acSelectionSetAll nil nil F_CODE F_VALE)
    Thank you.
    All AUGI, all the time Tharwat's Avatar
    2010-06
    874
    Default Re: Select all objects in current workspace
    Hi,
    Simply this.
    (setq f "")
    (while (setq l (tblnext "LAYER" (not l)))
      (or (/= (cdr (assoc 70 l)) 0)
          (minusp (cdr (assoc 62 l)))
          (wcmatch (setq n (cdr (assoc 2 l))) "*|*")
          (setq f (strcat n "," f))
    (setq ss (ssget "_X" (list (cons 8 (if (= f "") "*" f)) (cons 410 (getvar 'CTAB)))))
    2001-03
    ROMANIA
    24
    Quote Originally Posted by Tharwat View Post
    Hi,
    Simply this.
    (setq f "")
    Thank you Tharwat for your snippet.
    Unfortunately, the solution is not quite right because the name of the layer or layout could conflicts with one of the special characters used by the ssget function. See Lee Mac's explanation here.
    Run your snippet two times: without and with, let's say # character into the name of an active layer. In both cases, count the number of selected entities.
    Therefore, in order to avoid using the ssget function and an additional condition inside the code, I tried the solution with VLisp; these are drawings with thousands of entities and dozens of layers and the speed of the code is important.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    3,078
    Of course there's an obvious way of avoiding issues from using characters such as #, @, ., *, ?, etc when naming layers, files, etc. Just don't do it!
    Tom Beauford P.S.M. - Civil 2019 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
  1. 2016: Unable to select objects under other objects ona a locked layer
    By mattko in forum AutoCAD General
    Last Post: 2016-08-02, 03:18 PM
  2. Replies: 0
    Last Post: 2010-03-12, 06:09 AM
  3. Replies: 11
    Last Post: 2006-11-06, 06:43 PM
  4. Replies: 9
    Last Post: 2006-10-23, 02:30 PM
  5. Replies: 3
    Last Post: 2006-09-16, 04:01 PM
