Thread: Update a table data link in AutoCAD using VBA
    2017-01
    8
    Default Update a table data link in AutoCAD using VBA
    I have an issue, have an AutoCAD file with a ton of data links and would like to update only the data links related to a speciffic table. Simmilar to the functionality of selecting a table with data links, right clicking and selecting Update Table Data Links.
    i have the following code:
    Private Sub Update_table_data_link(tblRef As AcadTable)
    ThisDrawing.SendCommand "DATALINKUPDATE" & vbCr & "U" & vbCr & "K" & vbCr
    End Sub
    It works but updates all the data links in the drawing (which is a problem) so a perfect solution would either let me get what links are associated to tblRef
    and change the line to:
    ThisDrawing.SendCommand "DATALINKUPDATE" & vbCr & "U" & vbCr & "D" & vbCr & "datalink_name_from_tblRef" & vbCr
    or directly send the command to update the links to tblRef
    5,682
    Default Re: Update a table data link in AutoCAD using VBA
    Since you are using SendCommand, you can only process lisp at the command line. I wrote the following function to use by passing a vba entity to lisp. At the point in the prompt where it asks for an selection, you need to use the (handent) function to get a lisp ename. In vba, use a selection method to obtain a SelectionSet of the desired table. Iterate the ss to get the table object and pass it to the following function.
    Public Function Ent2lspEnt(entObj As AcadEntity) As String
        'Designed to work with SendCommand, which can't pass objects.
        'This gets an objects handle and converts it to a string
        'of lisp commands that returns an entity name when run in SendCommand.
        Dim entHandle As String
        entHandle = entObj.Handle
        Ent2lspEnt = "(handent " & Chr(34) & entHandle & Chr(34) & ")"
    End Function
    2017-01
    8
    End Function
    Ok got the function, selecting the table was already done, now the output of the function is "(handent "202AD81")"
    Now my ignorance kicks in again, how do I turn the handler into the datalink name needed for the "datalinkupdate" function?
    also, I'm not maried to datalinkupdate, I'm open to any other method that would update only the datalink attached to the selected table however my knowledge of lisp and .net is limited at best
    5,682
    The datalinkupdate command can also ask you to select a table object. Use that option.
    DATLINKUPDATE
    VbCR 'for the prompt to update
    prompt to select> pass in the handle
    ThisDrawing.SendCommand "DATALINKUPDATE " & VbCr & "(handent "202AD81")" & VbCr
    ThisDrawing.SendCommand "DATALINKUPDATE " & VbCr & Ent2lspEnt(objTable) & VbCr
    The above in untested for the syntax, you might need to add a space or two.
    2017-01
    8
    DATLINKUPDATE
    Sir you have been most helpfull, the exact syntax is as follows:
    ThisDrawing.SendCommand "DATALINKUPDATE " & vbCr & "U" & vbCr & Ent2lspEnt(tblRef) & vbCr & vbCr
    End Sub
    End Function
  1. 2016: Link mtext to autocad table data
    By chris.chan.215092 in forum AutoCAD Tables
    Last Post: 2016-03-09, 02:14 PM
  2. 2014: Autocad table from Excel Data Link
    By sovby254640 in forum AutoCAD General
    Last Post: 2014-08-07, 11:19 PM
  3. update link excel & table in acad2009
    By zardeg in forum AutoCAD Tables
    Last Post: 2011-06-03, 02:43 PM
  4. Replies: 3
    Last Post: 2006-11-30, 05:30 PM
