Results 1 to 6 of 6
Thread: drawline without GetMethod
    2018-04
    10
    Default drawline without GetMethod
    how to draw a line with out using the Get Method?
    Turlock, CA
    6,409
    Default Re: drawline without GetMethod
    The AddLine method requires a start point and an end point. How do you plan to get the points? Do you have them in a file or something?
    C:> ED WORKING....
    LinkedIn
    2018-04
    10
    i declared first for user to pick arbitrary point
    with that point i call it as x(0) and x(1)... began to draw line
    y(0) = x(0)
    y(1) = x(1) + 186.5455
    Set line = ThisDrawing.ModelSpace.AddLine(x, y)
    z(0) = y(0) + p(sn - 1) 'here is where_
    z(1) = x(1)
    Set line = ThisDrawing.ModelSpace.AddLine(x, z)
    2018-04
    10
    aim to draw this
    Turlock, CA
    6,409
    I would save it as a block and then insert it at the picked point and rotation. Unless the above symbol will always be oriented in the upright position, creating it with lines would be very tedious.
    C:> ED WORKING....
    LinkedIn
    2018-04
    10
    I was going to write the code and loop through every time the span of beam changes.
    Here is a code i have come so far please comment on it.
    Public Sub TestGetPoint()
    Dim varPick As Variant
    '' get input from user
    With ThisDrawing.Utility
    varPick = .GetPoint(, vbCr & "Pick a point: ")
    .Prompt vbCr & varPick(0) & "," & varPick(1)
    'draw the line
    Dim x(0 To 2) As Double
    Dim y(0 To 2) As Double
    Dim z(0 To 2) As Double
    Dim i(0 To 2) As Double
    Dim b(0 To 2) As Double
    Dim c(0 To 2) As Double
    Dim d(0 To 2) As Double
    Dim e(0 To 2) As Double
    Dim j(0 To 2) As Double
    Dim k(0 To 2) As Double
    Dim o As Integer
    Dim sc As Double
    Dim sm As Double
    Dim m As Integer
    Dim n As Integer
    '''' hree needed span(sn).. sn length...
    o = 5
    Dim p(0 To 100) As Double
    Dim f(0 To 100) As Double
    ' span length data
    p(0) = 2700
    p(1) = 2000
    p(2) = 2500
    p(3) = 2500
    p(4) = 2500
    ' column data
    f(0) = 400
    f(1) = 500
    f(2) = 600
    f(3) = 800
    f(4) = 800
    For sn = 1 To o
    'some hw .. if().. statmnt to pik
    If sn = 1 Then
    x(0) = varPick(0)
    x(1) = varPick(1)
    ' no need for go to
    ' _______GoTo_ty______' use the GoTo.. to escape
    '_______GoTo_ty______' use the GoTo.. to escape
    Else
    'here need code to do the first sum.. and assign variable kn to it
    For m = 2 To sn
    If m = 2 Then
    sm = p(m - 2)
    ' MsgBox (sm)
    Else
    sm = sm + p(m - 2)
    ' MsgBox (sm)
    End If
    Next m
    'here also need a code to do the sum .. and asign variable kc to it
    ' sn = 4
    For n = 2 To sn
    If n = 2 Then
    sc = f(n - 1)
    ' MsgBox (sm)
    Else
    sc = sc + f(n - 1)
    ' MsgBox (sm)
    End If
    Next n
    x(0) = varPick(0) + (sm) + (sc) ' dn=ln+cn .. ln = length of span cn = column thic
    ' x(0) = varPick(0) + ((sn - 1) * p(0)) + ((sn - 1) * 400) ' dn=ln+cn .. ln = length of span cn = column thic
    ' here i need smw
    ' use the fibinaci addition schema...
    ' need For loop here for ((sn-1)*3700)...
    x(1) = varPick(1)
    'here some how add the distance.. wanted to varpick(1)+###
    '_______GoTo_ty______start
    End If
    y(0) = x(0)
    'here you need to find ln or l(1)... from user..
    z(1) = x(1)
    i(0) = z(0)
    i(1) = z(1) + 186.5455
    Set line = ThisDrawing.ModelSpace.AddLine(z, i)
    ' here is where ... beam width is added..b1 say
    b(0) = y(0)
    b(1) = x(1) - 200 '..the length..
    c(0) = y(0)
    c(1) = b(1) - 186.5455
    Set line = ThisDrawing.ModelSpace.AddLine(c, b)
    'ehre s
    ' here needs also sm...
    ' if sm=0.. then === p(0)
    d(0) = b(0) + p(sn - 1) ' here is where l(1) goes
    d(1) = b(1)
    Set line = ThisDrawing.ModelSpace.AddLine(b, d)
    e(0) = d(0)
    e(1) = d(1) - 186.5455
    Set line = ThisDrawing.ModelSpace.AddLine(d, e)
    If sn = 1 Then
    k(0) = c(0) - f(0) ' here add column width c1
    k(1) = c(1)
    j(0) = x(0) - f(0) 'here add c1
    j(1) = y(1) ' jtotal = 2*186.5455 + b1 here add c1
    Set line = ThisDrawing.ModelSpace.AddLine(k, j)
    line.Update
    Else
    line.Update
    End If
    '_____ this is where the (span length of above 1) s1 > 1 ends...
    Next sn 'loop for sn
    End With
    End Sub
