Results 1 to 6 of 6
Thread: Sheet set prompting to chose template FILE when creating new sheet.
    2011-09
    308
    Default Sheet set prompting to chose template FILE when creating new sheet.
    Hiya gang,
    Hope this is the correct forum for this, please feel free to move if it's not.
    Simple question (I think).
    • I have a sheet set with a sheet creation template defined.
    • This template has several layouts (Arch D, Arch E, etc)
    • "Prompt for template" is set to yes.
    When I create a new sheet I am prompted to select the template file every time and I don't remember this being the case, I thought it "remembered" the file and let you choose from the layouts in that file.
    Am I nuts? Did it always work this way or am I missing something?
    Thanks as always.
    2009-11
    5,719
    Default Re: Sheet set prompting to chose template FILE when creating new sheet.
    What happens when you change 'Prompt for template' to No?
    Computer Specs:
    2011-09
    308
    Hello Black Box!
    If I do that, it behaves exactly as I expect.
    AutoCAD "remembers" both the file and the layout and never prompts me for anything and simply creates a new sheet using the Layout defined in the "Select a layout as sheet template" dialog box.
    2009-11
    5,719
    #FlashbackFriday
    Computer Specs:
    2011-09
    308
    Ha! Well the issue is the client wants to be able to select from the several layouts in that file, but browsing to the file itself every time you make a sheet is a drag.
    A-team forever!
    2009-11
    5,719
    Isn't that what sub-sets are for?
    I get what the client wants, but that's not currently possible (without sub-sets that have a Layout specified + no prompt for DWT), AFAIK.
    Computer Specs:
  1. Sheet Set Template File Location in c#
    By oakam430373 in forum RealDWG
    Last Post: 2017-09-04, 01:47 AM
  2. Replies: 5
    Last Post: 2010-06-04, 06:45 PM
  3. Creating Sheet set template
    By Joshua.Shea in forum AutoCAD Sheet Set Manager
    Last Post: 2009-06-12, 01:58 PM
  4. SSM not using correct sheet template file
    By tim.101799 in forum AutoCAD Sheet Set Manager
    Last Post: 2007-04-26, 07:55 PM
  5. Sheet 1 of 1 as updating feature to a Master Sheet Set template
    By avdesign in forum AutoCAD Sheet Set Manager
    Last Post: 2006-01-20, 12:14 PM
