Thread: Recover a file
    2005-01
    59
    Default Recover a file
    I recently had a thumb drive go bad that had about 150 .dwg files on it. The drive was unrecognized when inserted into the USB slot and I ended up using EaseUS to recover most of the drive. There are still about 20 files that when attempting to open come up "Drawing file is not valid". There is some info there as the file directory shows file sizes of 150-200 KB. I have tried the different recovery methods covered in knowledge.autodesk.com but nothing seems to work.
    Reaching here a bit, is it possible to open the file in something like WordPad and replace the header or other metadate or even cut and paste into a known good file? Any other suggestions are welcome.
    Thanks!
    Earth
    9,771
    Default Re: Recover a file
    Not that I've ever seen. It's not like an XML file, it's all binary.
    Not saying it's impossible, but it would take someone with internal knowledge of the DWG file format, which is not publicly documented.
    R.K. McSwain | CAD Panacea |
    Turlock, CA
    5,735
    I've had a few drawings that had been truncated at the end. I was able to open them in Inventor. It seems to have less stringent file validation than AutoCAD. If you want to email me a sample file, I could try it for you. Send to ed.jobe at augi dot com
    C:> ED WORKING....
  1. 2014: How To Recover AutoCAD DWG File ?
    By thomashubba19691968 in forum AutoCAD General
    Last Post: 2015-02-18, 02:12 PM
  2. Recover a drawing file when the Recover command fails
    By a_meteni in forum AutoCAD General
    Last Post: 2014-07-02, 03:34 PM
  3. Recover a file using the journal?
    By john.hainsworth in forum Revit Structure - General
    Last Post: 2008-05-15, 09:28 AM
  4. Recover a Drawing File
    By rhayes.99001 in forum ACA General
    Last Post: 2007-06-29, 06:38 PM
  5. Unable to recover a DWG file
    By martyk in forum AutoCAD General
    Last Post: 2006-12-05, 06:55 PM
