Thread: Copy with Base Line Command
    Post Copy with Base Line Command
    I need to select an object, receive a prompt for selecting a baseline to copy it by (serving the purpose of a base-point for position, but also incorporating rotation). Then prompt for two points by which to paste the object back down, matching the new angle and centering it on the new midpoint. I need the paste functionality to repeat just as the normal copy function does. One of my jobs involves repeatedly copying and orienting the same objects along different angles, and this would be a huge help.
    Thanks for any help.
    Default Re: Copy with Base Line Command
    If possible, it may be more useful to be prompted for the new angle selected with two points and then have a separate prompt for the position, instead of centering its position along the selected points.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    3,094
    I'm guessing you mean to copy a selected object from a point on the baseline perpendicular from geometric center from the selected object to other points on the baseline using nearest osnap and rotated perpendicular to those points.
    Would the ARRAYPATH command take care of what you need?
    How about Lee Mac's http://www.lee-mac.com/objectalign.html
    maybe https://forums.autodesk.com/t5/visua...855981#M320194
    Tom Beauford P.S.M. - Civil 2019 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    I can't make use of these for the same purpose, because I'm not working with a continuous curve or polyline. If I were to pick up LISP as a novice, would this be a difficult command to program?
    2001-03
    Tallahassee, FL
    3,094
    Very difficult for a novice, Lee's code will work with a Line, Polyline, Arc, Circle, Ellipse, XLine, Spline etc. I thought it looked exactly like what you were looking for.
  1. 2017: Failure to copy with base point
    By tadthurston725387 in forum AutoCAD Civil 3D - General
    Last Post: 2018-07-28, 01:24 AM
  2. Copy/Paste Coordinates to Command Line
    By IanR in forum AutoCAD Wish List
    Last Post: 2012-08-05, 06:32 AM
  3. Copy by base point?
    By Blakester122 in forum Revit MEP - General
    Last Post: 2009-10-02, 07:09 PM
  4. Copy with base point
    By thechinaman in forum AutoCAD General
    Last Post: 2007-07-24, 03:47 PM
  5. Remove Copy History from Command Line Right Click Menu
    By jelder in forum AutoCAD Customization
    Last Post: 2004-11-18, 07:38 PM
Tags for this Thread
