Thread: corridor hole
    2004-06
    Slidell, Louisiana
    972
    Default corridor hole
    What would be the best way to handle the situation shown in the attached picture. it's a simple road with a loop back into itself. one continuous alignment.
    the corridor worked fine except for the inside intersection as shown. should i have created two separtely named alignments and used the intersection wizard?
    i tried using it, but with only the one named alignment it didn't work.
    2020-12
    8
    Default Re: corridor hole
    Quote Originally Posted by rmk View Post
    Can you post your drawing I would like to see what you have done before I comment. but generally speaking Civil 3D does not like self interlinking when it comes to Alignments, especially if you use Offset alignments to target your ETW and bellmouths
    Arizona
    2,478
    a small alignment (or feature line) across that gap so that you can allow your assembly to target it.
    Keep in mid, the there really isn't a 'hole' there when you create a surface from the corridor data
  1. Corridor LandXML to include the true corridor & associated objects
    Last Post: 2015-11-16, 11:00 AM
  2. Create Offset Hole from Hole
    Last Post: 2012-09-06, 02:37 AM
  3. Options for hole callout placement for Hole Table patterns
    Last Post: 2007-09-19, 04:42 AM
  4. Option to Select a Hole Sketch Pattern as a Hole Pattern Feature
    Last Post: 2007-06-01, 04:21 AM
