Thread: Auto CAD is not Opening from Excel
    2018-04
    10
    Default AutoCAD is not opening from Excel
    Help Urgently needed... here is the line of code
    The error is
    Thanks
    Turlock, CA
    6,419
    Default Re: Auto CAD is not Opening from Excel
    There is no application called "Jo-PC". The argument is supposed to be the class ID of a program, e.g. AutoCAD. To find out what you need to use, open REGEDIT.exe and navigate to HKEY_Classes_Root and scroll down to the "AutoCAD" section. The value should be something like "AutoCAD.Application". If you have multiple versions of AutoCAD installed, you can open a specific version by adding the version number. For 2018, mine is "AutoCAD.Application.22". 2019 is "AutoCAD.Application.23".
    As written, your code will always open a new instance of AutoCAD. If AutoCAD is already open, you could use that instance instead. See this post for some sample code. Don't forget to reset by using On Error GoTo 0.
    C:> ED WORKING....
    LinkedIn
  1. Excel to Auto cad block attributes
    By pksen515343 in forum AutoCAD General
    Last Post: 2012-01-23, 12:26 PM
  2. how to activate AutoCAD after opening Excel?
    By Yancka in forum VBA/COM Interop
    Last Post: 2009-11-08, 08:17 PM
  3. Auto Printing CAD Viewports without opening CAD??
    By BoarsNest01 in forum CAD Management - General
    Last Post: 2009-05-17, 11:04 AM
  4. Auto Update Option for MS Excel Created Parts
    Last Post: 2007-09-19, 03:30 AM
  5. Replies: 2
    Last Post: 2006-04-25, 02:36 PM
