The Building Section has disappeared. The section exists but the Building Section has disappeared. How do I come back? I used Reveal Hidden Elements and it does not appear on either side of the other.
Disappeared from where? In the view, Project Browser, Type Selector in the Properties Palette?
In the view, the section/elevation parameter Hide in Views Coarser Than affects visibility. For example, if the view is 1:100 and the section is set to 1:200 the section won't appear in the view. If it is missing from the Project Browser then it has been deleted. The Type Selector means it has probably been purged from the project, you'll need to create a new Type or Copy/Paste from another project that has the type.
Is it on the plans views that the section has disappeared? Then check the section's Phasing. If the Section's Phasing is set to "Existing" & the Plan is set to "New Construction" phase - the section won't show up.
