Thread: can we combine in one command
    2009-09
    2
    Default can we combine in one command
    this is 2 lisp
    (defun c:22SelectsBlockLayer0 ( / idx lst sel )(if (setq sel (ssget '((0 . ""INSERT""))))(repeat (setq idx (sslength sel))(block->0 (cdr (assoc 2 (entget (ssname sel (setq idx (1- idx)))))))))(command ""_.regen"")(princ))(defun block->0 ( blk / ent enx )(cond( (member blk lst))( (setq ent (tblobjname ""block"" blk))(while (setq ent (entnext ent))(entmod (subst-append 8 ""0"" (subst-append 62 256 (setq enx (entget ent)))))(if (= ""INSERT"" (cdr (assoc 0 enx)))(block->0 (cdr (assoc 2 enx)))))(setq lst (cons blk lst)))))(defun subst-append ( key val lst / itm )(if (setq itm (assoc key lst))(subst (cons key val) itm lst)(append lst (list (cons key val)))))
    (defun c:22SelectsBlockAllByBlock (/ *error* adoc lst_layer func_restore-layers)
     (defun *error* (msg)
       (func_restore-layers)
       (vla-endundomark adoc)
       (princ msg)
       (princ)
       ) ;_ end of defun
     (defun func_restore-layers ()
       (foreach item lst_layer
         (vla-put-lock (car item) (cdr (assoc ""lock"" (cdr item))))
         (vl-catch-all-apply
           '(lambda ()?
              (vla-put-freeze
                (car item)
                (cdr (assoc ""freeze"" (cdr item)))
                ) ;_ end of vla-put-freeze
              ) ;_ end of lambda
           ) ;_ end of vl-catch-all-apply
         ) ;_ end of foreach
       ) ;_ end of defun
     (vl-load-com)
     (vla-startundomark
       (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
       ) ;_ end of vla-startundomark
     (if (and (not (vl-catch-all-error-p
                     (setq selset
                            (vl-catch-all-apply
                              (function
                                (lambda ()
                                  ) ;_ end of lambda
                                ) ;_ end of function
                           ) ;_ end of setq
                     ) ;_ end of vl-catch-all-error-p
                   ) ;_ end of not
              selset
              ) ;_ end of and
       (progn
         (vlax-for item (vla-get-layers adoc)
           (setq
             lst_layer (cons (list item
                                   (cons ""lock"" (vla-get-lock item))
                                   (cons ""freeze"" (vla-get-freeze item))
                                   ) ;_ end of list
                             lst_layer
                             ) ;_ end of cons
             ) ;_ end of setq
           (vla-put-lock item :vlax-false)
           (vl-catch-all-apply
             '(lambda () (vla-put-freeze item :vlax-false))
           ) ;_ end of vlax-for
         (foreach blk_def
                  (mapcar
                    (function
                      (lambda (x)
                        (vla-item (vla-get-blocks adoc) x)
                        ) ;_ end of lambda
                    ((lambda (/ res)
                       (foreach item (mapcar
                                       (function
                                         (lambda (x)
                                           (vla-get-name
                                             (vlax-ename->vla-object x)
                                             ) ;_ end of vla-get-name
                                           ) ;_ end of lambda
                                       ((lambda (/ tab item)
                                          (repeat (setq tab  nil
                                                        item (sslength selset)
                                                        ) ;_ end setq
                                            (setq
                                              tab
                                               (cons
                                                 (ssname selset
                                                         (setq item (1- item))
                                                         ) ;_ end of ssname
                                                 tab
                                                 ) ;_ end of cons
                                              ) ;_ end of setq
                                            ) ;_ end of repeat
                                          tab
                                          ) ;_ end of lambda
                                       ) ;_ end of mapcar
                         (if (not (member item res))
                           (setq res (cons item res))
                           ) ;_ end of if
                         ) ;_ end of foreach
                       (reverse res)
                       ) ;_ end of lambda
                    ) ;_ end of mapcar
           (vlax-for ent blk_def
             (vla-put-layer ent ""0"")
             (vla-put-color ent 0)
             (vla-put-lineweight ent aclnwtbyblock)
             (vla-put-linetype ent ""byblock"")
           ) ;_ end of foreach
         (vla-regen adoc acallviewports)
         ) ;_ end of progn
       ) ;_ end of if
     (princ)
     ) ;_ end of defun"
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,658
    Default Re: can we combine in one command
    You need to edit your post and Wrap Code tags around the code.
    Clicking the [Go Advanced] button at the bottom puts a toolbar at the top and the # icon in that toolbar places code tags around selected text for you or simply paste your code inside.
    AUGI Addict madcadder's Avatar
    Too far from the beach
    1,054
    Are you just wanting them to run back to back?
    Is it as easy as?
    Create a new command at the top (Defun C:Runboth () (22SelectsBlockLayer0) (22SelectsBlockAllByBlock))
    Removing the "C:" from both routines
    Call it done...
    (It's usually never that easy)
    2001-03
    Tallahassee, FL USA
    3,658
    Actually there's four routines up there 22SelectsBlockLayer0, block->0, subst-append, and 22SelectsBlockAllByBlock.
    block->0 has badly mismatched parentheses and subst-append has a single double-quote at the end.
    Until sadikozer34 responds explaining what he wants the code to do and posts it correctly not much we can do.
    When posting code it's best to post the link where you found it as it's the best source of information about the code as well as paying respect to it's author.
    Earth
    9,803
    A lot of it came from here: https://www.cadtutor.net/forum/topic...s#comment-8758
    R.K. McSwain | CAD Panacea |
  1. 2014: Convert and Combine
    By neorider99519183 in forum Inventor - General
    Last Post: 2014-04-03, 02:55 PM
  2. Combine
    By Loc in forum AutoLISP
    Last Post: 2009-11-04, 06:15 PM
  3. combine different sheets to one dwg?
    By eveofdestruction in forum AutoCAD General
    Last Post: 2009-09-28, 06:38 PM
  4. combine mtext
    By dion.99596 in forum AutoCAD Customization
    Last Post: 2008-01-29, 04:48 PM
  5. Can I combine .pan files into an AVI?
    By Max Lloyd in forum Revit Architecture - General
    Last Post: 2005-03-03, 11:24 PM
