Thread: text mask issue
    2004-06
    Slidell, Louisiana
    743
    Default text mask issue
    I am having a problem with text mask. see the attached images. It's wiping out the text i want visible.
    any ideas?
    Robert
    Tallahassee, FL
    3,074
    Default Re: text mask issue
    Best solution is to start using MTEXT which has Background Mask as a property.
    Attached lisp toggles Background Mask On/Off and will convert TEXT to MTEXT as needed.
    Tom Beauford P.S.M. - Civil 2019 on Windows 10 Enterprise
    Ph# (850)606-1516 Home Page
    2004-06
    Slidell, Louisiana
    743
    thanks Tom. I thought engaging the object grouping in the selection tab of the options. seems to work on my machine, but others in the office area still having the issue after the change.
    i do use mtext all the time, but others are still using dtext and like to use the express tools to mask.
    Robert
    Tallahassee, FL
    3,074
    It appears either the view is TWisted or a different coordinate system was used for the wipeout. While that's fixable a wipeout will never automatically adjust with text size or alignment modifications like MTEXT Background Mask.
    Historically there's been issues with some plotters and 3rd party DWG to PDF drivers that output wipeouts as solid black. It's been a long time since I've used wipeouts myself.
    2004-06
    Slidell, Louisiana
    743
    no, just the text i wanted masked is rotated so it would overlap the other.
    Robert
    2015-05
    West Des Moines
    253
    Quote Originally Posted by rmk View Post
    While I joke a lot about how there are a thousand ways to skin a cat ultimately some are inferior to others. Sometimes one workflow gives you something you want that another doesn't so it's grey there on what the best practice is going to be. If someone is choosing the use a a workflow just because it's what they know then that's fine until it creates issues avoidable by another (honestly even easier) workflow then the answer should be start doing that workflow. At a certain point it just becomes a matter of being right or wrong.
    I will say that based on your images the wipeout text needs to be sent to the back (and/or the text to the front) and if that's not working then read the above again.
  1. text mask deletes text
    By gingermick in forum AutoCAD Annotation
    Last Post: 2016-12-15, 05:59 PM
  2. 2012: Text Mask Issue
    By rbhazie in forum AutoCAD General
    Last Post: 2016-04-18, 05:52 PM
  3. 2011: Text Mask looses text
    By ccook79 in forum AutoCAD General
    Last Post: 2010-11-19, 08:39 PM
  4. Replies: 8
    Last Post: 2007-07-03, 04:25 PM
  5. Updating Text Mask once Text has been edited
    By r_soula in forum AutoCAD General
    Last Post: 2007-06-05, 03:05 AM
