Thread: change the plot scale with autolisp
    2014-11
    17
    Default change the plot scale with autolisp
    how do you change the Plot Scale on the layout page setup with autolisp
    Tallahassee, FL
    3,074
    Default Re: change the plot scale with autolisp
    You could use a macro, script, or lisp command macro using the -PLOT command, and after the prompt:
    "Enter plot scale (Plotted Inches=Drawing Units) or [Fit] <1:1>: "
    Enter 1:96
    - - - Updated - - -
    I have a list of saved Page Setups with a drop-down in my Ribbon that imports whichever I select. Many different ways to do this.
    Tom Beauford P.S.M. - Civil 2019 on Windows 10 Enterprise
    Ph# (850)606-1516 Home Page
  1. Replies: 9
    Last Post: 2015-08-21, 06:33 PM
  2. Autolisp to plot Co-Ordinates in dwg to printer
    By rickfelton347645 in forum AutoLISP
    Last Post: 2013-10-21, 02:17 PM
  3. AutoLISP function to change DB's values
    By truevis in forum Dynamic Blocks - Technical
    Last Post: 2007-11-19, 05:31 AM
  4. SCALE SCALE SCALE!!!!
    By victoria in forum AutoCAD General
    Last Post: 2007-11-08, 11:05 PM
  5. Plot 2 No Copies. 1st Plot is ok! 2nd Plot moves on the paper.
    By gianluca.giusti in forum AutoCAD Plotting
    Last Post: 2006-05-18, 11:02 AM
