Thread: Site plans - buildings only cast shadows partially.
    2012-07
    Default Site plans - buildings only cast shadows partially.
    hi there,
    I have a site plan that shows several city blocks and I want all the buildings in them to cast shadows, however only a small portion of them are doing so (the ones that are in the area as if I had started this for a single building project). I started this from an architectural template. I cannot solve this, anyone can help please?
    thanks a lot
    Paul
    2015-12
    102
    Default Re: Site plans - buildings only cast shadows partially.
    Strange. The only way I could replicate this was to use a toposurface to catch the shadows for some of the buildings but not others:
    But as soon as I tried to make the toposurface itself not visible, the shadows disappeared, too.
    When using a level as a ground plane in Sun Settings, the shadows of all the buildings were visible even if the extents of the level were not below any of the buildings.
    I did experiment to see if phasing made any difference, the way it can do with materials, but no go. (The E is an existing building, the N is new construction.)
    I'm stumped, too.
  1. 2012: Mass Cast Shadows
    By ctc in forum Revit Architecture - General
    Last Post: 2014-02-09, 10:40 PM
  2. Cast quantity, concrete cast surface
    Last Post: 2013-10-25, 11:44 AM
  3. Mass Objects able to cast shadows in plan?
    By aeckhoff in forum Revit Architecture - General
    Last Post: 2008-04-04, 06:56 PM
  4. (Semi) transparent materials should still cast shadows
    By ron.sanpedro in forum Revit Architecture - Wish List
    Last Post: 2007-08-27, 07:14 AM
Tags for this Thread
