Results 1 to 10 of 15
Thread: Date Attribute in title block
    2016-11
    5
    Default Date Attribute in title block
    I have a title block with a date attribute: %<\AcVar date \f "%#x">% which indicates the current date when I insert my title block but which, when I open my drawing a few days later, the date does not change for the current date. how to make sure that this attribute always indicates the current date on which the drawing is open. Thanks!!
    2005-06
    in the upper right corner
    3,507
    Default Re: Date Attribute in title block
    Quote Originally Posted by Axys Bruno View Post
    Congrats on your first post.
    I thought I replied to this and sorry if a duplicate shows up..
    If this is a field (which it looks like it is) check out your variable setting: FIELDEVAL
    2016-11
    5
    O.K. the variable "fieldeval" is set to 31
    2005-06
    3,507
    With that said, it should update with the "UPDATEFIELD" command
    2016-11
    5
    Okay, but, my title block is on each of the tabs of my drawing so I have to do this command in each of the tabs. Is there a command that would update all my tabs.
    2005-06
    3,507
    I don't know for sure but what happens if you type "all" when prompted?
    <command> UPDATFIELD > select object > ALL <enter>
    2016-11
    5
    This only updates the title block of the active tab. I tried by selecting all the tabs but with the same result.
    2005-06
    3,507
    There's probably a way to do this with script or lisp, maybe someone else out there has some thoughts..
    To apply to all the block names "TEST" in all the layouts.
    something like this but grabbing all the layouts escapes me..
    (I hacked together some code from other routines but I don't know what I'm doing)
    (defun c:dupdate (/ TB)
    (setvar "fieldeval" 31)
    (setq TB (ssget "x" '((0 . "INSERT")(2 . "TEST")(410 . "*"))))
    (foreach lay (layoutlist)
    (command "updatefield" TB "" )
    2001-03
    Tallahassee, FL USA
    3,667
    As it would automatically update on plot, save, or regen does it really make any difference what it looks like while you're just editing the drawing?
    2005-06
    3,507
    Good point, but I'm not sure that is true.
    According to ACAD, the date field doesn't automatically update according to the "FIELDEVAL" settings and that you need to use "UPDATEFIELD"
  1. Change block attribute with today date
    By Arterius in forum AutoLISP
    Last Post: 2015-07-14, 03:04 AM
  2. 2013: date parameter in title block (sheet)
    By jledgewood in forum Revit - Platform
    Last Post: 2014-03-18, 03:14 PM
  3. Copy previous Block Attribute Value to next Block Attribute
    By CADfunk MC in forum VBA/COM Interop
    Last Post: 2009-02-27, 09:46 PM
  4. Creating An Attribute Block For Revision or Title Block
    By fnguyen05 in forum AutoCAD General
    Last Post: 2005-12-22, 03:14 PM
  5. Convert MDT Title Block to Inventor 10 Title Block
    By julesgordon in forum Inventor - General
    Last Post: 2005-07-18, 08:34 PM
