Thread: Lisp program needed
    I could stop if I wanted to cadd4la's Avatar
    2001-12
    Newport Beach, CA
    399
    Default Lisp program needed
    Hello, I'm looking for a lisp that will do the following:
    Xref in a file by opening a window that will start in the same dir file folder as the drawing the code is used in to locate the file, turning on the node osnap, place it on layer "XREF", and scale it by 1/ the dimscale of the drawing being xref in (for example: 1/2"=1'-0" (1/24), 1/4"=1'0" (1/4 or is the dimscale is set to 1 it don't scale it by 1/ the dimscale).
    Thanks,
    Cadd4LA
    I could stop if I wanted to CadDog's Avatar
    So Ca
    439
    Default Re: Lisp program needed
    Is this what some you're looking for...?
    We an attack lisp which create a layer to place the attachment and also make sure to make it an overlay.
    The layers it create are $xref- and uses the name of the file you selected.
    2001-12
    Newport Beach, CA
    399
    Quote Originally Posted by CadDog View Post
    Sorry, I don't understand your attachment.
    I do want it to come in as a overlay.
    Thanks,
  1. Program needed part 2
    By cadd4la in forum AutoLISP
    Last Post: 2013-12-31, 08:25 PM
  2. Replies: 8
    Last Post: 2011-03-29, 07:33 AM
  3. reactor based simple lisp program needed
    By rajat_bapi_mallick in forum AutoLISP
    Last Post: 2007-10-11, 10:21 PM
  4. Writing a Short program from Large Program
    By avinash00002002 in forum VBA/COM Interop
    Last Post: 2006-07-13, 01:26 AM
