Thread: Lost parcels from a parcel revision
    2009-11
    Raleigh, NC
    941
    Default Lost parcels from a parcel revision
    You can see the remaining parcels with yellow labels.
    The lots that dont have a civil 3d parcel labels were deleted from editing the cul de sac ROW to the far right. All the parcel lines and ROW are still parcel segments and are all still connected.
    Whats the best way to create them as parcels again?
    2015-10
    Central New Jersey
    439
    Default Re: Lost parcels from a parcel revision
    Any chance thru editing that the entire ROW parcel was moved to the right, which in turn left the parcels to the left open where their side lines meet the ROW?
    2009-11
    Raleigh, NC
    941
    After tinkering around I can say definitively that the ROW parcels or any others parcels or parcel segments were moved. I did extend the parcel segments past the ROW and then pull them back to the ROW and it started picking back all the parcel labels then. Obviously it renumbered them. Anyway, Just a little hickup.
  1. Halftone option for showing revision clouds within revision manager.
    Last Post: 2011-12-02, 04:22 PM
  2. Revision Clouds line weight different per Revision
    By billy007nh in forum Revit Architecture - General
    Last Post: 2010-11-18, 05:55 PM
  3. How do I delete a revision from the revision schedule?
    By Blakester122 in forum Revit MEP - General
    Last Post: 2009-10-20, 02:24 PM
  4. Import GIS Parcel data to C3D Parcels with extended data
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2009-10-06, 04:51 PM
  5. Revision Delta in Revision Schedule.
    By doh in forum Revit Architecture - General
    Last Post: 2009-08-13, 06:19 PM
