Thread: Alignment label cannot calculate station and offset
    2016-05
    8
    Default Alignment label cannot calculate station and offset
    Hi All
    When i try to add station/offset labels into my drawing, sometimes it cannot calculate the station/offset, and I cannot understand why.
    The first image below shows tow labels which are very close to each other. The one which works is snapped to a point somewhere along the green polyline.
    The one which isnt working is very close to it, but snapped to the endpoint of the green polyline.
    The second image shows you a close up of the two points and where they
    I noticed this problem when trying to build a custom command using the VB.NET API. The call to the "stationoffset" function also returned an error.
    I then tried it using alignment labels, to find they produce the same result
    Any ideas what might be causing this?
    Tallahassee, FL
    3,117
    Default Re: Alignment label cannot calculate station and offset
    There's a deflection in the alignment so the offset up to that point does not meet the offset beyond that point leaving a gap that isn't stationable. Adding a horizontal curve at the deflection would solve the problem.
    Tom Beauford P.S.M. - Civil 2019 on Windows 10 Enterprise
    Ph# (850)606-1516 Home Page
    9,604
    Exactly. To illustrate graphically....Given the alignment (in magenta), the area in red will have no station/offset. The area in green will have two solutions.
    If you must use a PI in the alignment, then you can calculate a bearing and distance to your desired point, from the PI.
  1. Point Lable Style with Station and offset from alignment
    Last Post: 2016-10-23, 02:21 AM
  2. 2011: label points at an offset from alignment showing stat, offset, and description
    By mw156 in forum AutoCAD Civil 3D - Survey
    Last Post: 2016-09-29, 06:10 PM
  3. Alignment Station label that is perpendicular to alignment
    By corboto in forum AutoCAD Civil 3D - Alignments
    Last Post: 2010-05-20, 10:43 PM
  4. Alignments - Label Station and Offset
    By todd.80290 in forum Land Desktop - General
    Last Post: 2009-12-10, 09:39 PM
  5. Alignment with station and offset?
    Last Post: 2006-03-27, 11:58 PM
