Thread: Lookup Help
    2005-12
    Columbus, OH
    155
    Default Lookup Help
    Hi everyone! I'm hoping someone to help me with a small problem I'm having with a dynamic lookup option. Everything, but one lookup works fine. The file attached is our drawing title with attributes, two visibility states, and a lookup. The lookup is for all architectural scales. The block will display every scale correctly but the 1/8" scale. If anyone could help me with this it would be great.
    2005-12
    Columbus, OH
    155
    Default Re: Lookup Help
    I'm note sure what was wrong but I was able to fix the problem. I fixed the length of the lookup parameter and then removed the 1/8" from the list, then added it back. I then went to the lookup and told it to look at the new 1/8" list setting.
    Attached is the fixed version.
    Matt
  1. Lookup Properties Visibility states settings in A Lookup Table
    Last Post: 2017-12-01, 05:53 PM
  2. 2016: Lookup based on a Lookup
    By dkennard in forum Dynamic Blocks - Technical
    Last Post: 2017-01-20, 12:59 AM
  3. Help! Lookup Table Possible?
    By mark.mcmullan in forum Revit MEP - Families
    Last Post: 2009-12-02, 05:27 PM
  4. HELP! ! ! W/ Lookup Table
    By TerribleTim in forum Dynamic Blocks - Technical
    Last Post: 2008-09-10, 09:48 PM
  5. Dynamic Blocks Lookup Table Help
    By dmay in forum Dynamic Blocks - Technical
    Last Post: 2005-10-18, 02:48 PM
Tags for this Thread
