Results 1 to 1 of 1
Thread: Flipping Attributes in Block Editor
    2019-05
    Default Flipping Attributes in Block Editor
    I am creating a block for match-line to indicate on the mechanical sheet where work continues on other sheets.
    I am using flip command to flip the sheet number and the hatch pattern. If I associate one of the attributes and both hatch patterns to flip about the horizontal axis then that one attribute will flip properly. however, if I select both attributes and both hatches to flip about the same axis then the hatches will flip properly but the attributes stay in the same location. I have looked at other forums and some have identified that the lock position needs to be "yes" and they both are.
    Thanks for the help in advance and I can provide more information if needed.
  1. Flipping Text Attributes
    By bap020799 in forum Dynamic Blocks - Technical
    Last Post: 2013-07-11, 12:38 PM
  2. Flipping Action Commands in Block Editor
    By sam.121498 in forum Dynamic Blocks - Technical
    Last Post: 2010-01-27, 10:46 PM
  3. Highlight Last Opened Block in Block Editor Block List
    Last Post: 2008-10-11, 09:03 PM
  4. When flipping a Dynamic Block, grips do not flip with the block
    By n.g in forum Dynamic Blocks - Technical
    Last Post: 2007-04-16, 12:59 PM
  5. Flipping Attributes in Dynamic Blocks
    By lwhite.49103 in forum Dynamic Blocks - Technical
    Last Post: 2006-04-26, 05:24 PM
