Thread: CENTEREXE set to percentage of the Diameter
    2017-06
    Newport News, VA USA
    7
    Default CENTEREXE set to percentage of the Diameter
    You should be able to set (for example) CENTEREXE to ".15d". CENTEREXE should be able to find circle diameter, and adjust the extension to be a specific percentage. Add type-in capability in defineing CENTEREXE so the centermark extensions (whiskers outside the circle) are a percentage of the circle diameter. I like them to be 15% of the circle diameter, myself. Using a constant distance works for circles of similar size, but huge or tiny circles need a new distance. I USED to make centermarks with one of the three CENTER linetypes, across quadrants, scaled 1.3 from the center, and maybe LTS or Linetype Scale in properties adjusted. Wish this could be done with the setting to CENTEREXE. -paul
    Note: I tried to add this to the Wish List, but couldn't get past the required application dro down list. Maybe my brouzer is old?
    2001-12
    St. Louis
    5,403
    Default Re: CENTEREXE set to percentage of the Diameter
    Quote Originally Posted by p_burgener751498 View Post
    With the Wishlist, you do have to have the product you want to submit a list for, under your profile here as a product that you use.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2001-12
    St. Louis
    5,403
    Quote Originally Posted by Wanderer View Post
    https://www.augi.com/account/products
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2017-06
    7
    Thanks, Melanie. I expected there to be a big drop down list on the Wish site. I've got it fixed now. -paul
    2001-12
    St. Louis
    5,403
    Great, thanks for the follow up!
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. Percentage of wall openings
    By angelo in forum Revit Architecture - General
    Last Post: 2010-04-14, 03:06 PM
  2. Task scheduler tool tip display percentage completed
    Last Post: 2009-02-01, 06:51 PM
  3. creating percentage summary of areas
    By jacek.brzezowski in forum Revit - Platform
    Last Post: 2008-10-20, 08:10 AM
Tags for this Thread
