Thread: Lisp to delete named page setups not working...
    2011-09
    308
    Default Lisp to delete named page setups not working...
    Hiy aagain gang.
    here's another routine that is baffeling me.
    It's supposed to delete a bunch of named page setups (based on wildcards), and then add back certain page setups based on the vale of INSUNITS.
    When it gets to the part that is supposed to delete them (in red below) it fails with:
    "error: no function definition: VLAX-GET-ACAD-OBJECT"
    ;;; DELETES ALL STANDARD NAMED PAGE SETUPS AN IMPORTS BASED ON INSUNITS ;;;
    ;;;This section collects page setup names ;;;
    (vl-load-com)
    (defun DeleteOldPageSetup ( Name / Cfgs)
    (setq Cfgs
     (vla-get-plotconfigurations
     (vla-get-activedocument
     (vlax-get-acad-object))))
    (cond
     ((vl-string-search "*" Name)
      (vlax-for x Cfgs
       (if (wcmatch (vla-get-name x) Name)
        (vla-delete x)
     (T
      (vl-catch-all-apply
        '(lambda () (vla-delete (vla-item Cfgs Name)))
    ;;; This section deletes the page setups - add names as needed ;;;
    (DeleteOldPageSetup "*_COLOR*")
    (DeleteOldPageSetup "*_PAPER*")
    (DeleteOldPageSetup "*_PDF*")
    (DeleteOldPageSetup "*_Metric*")
    ;;; IMPORTS NAMED PAGE SETUPS
    (cond ((= (getvar "INSUNITS") 1) (command "._-PSETUPIN" "Z:/ACA 2019/Drawings/MVVA Pagesetups.dwg" "*"))
          ((= (getvar "INSUNITS") 2) (command "._-PSETUPIN" "Z:/ACA 2019/Drawings/MVVA Pagesetups.dwg" "*"))
          ((= (getvar "INSUNITS") 4) (command "._-PSETUPIN" "Z:/ACA 2019/Drawings/MVVA Metric Pagesetups.dwg" "*"))
          ((= (getvar "INSUNITS") 5) (command "._-PSETUPIN" "Z:/ACA 2019/Drawings/MVVA Metric Pagesetups.dwg" "*"))
          ((= (getvar "INSUNITS") 6) (command "._-PSETUPIN" "Z:/ACA 2019/Drawings/MVVA Metric Pagesetups.dwg" "*"))
    Thanks as always for any guidance.
    -JP
    Tallahassee, FL USA
    3,667
    Default Re: Lisp to delete named page setups not working...
    I use your DelPageSetup by Jason Piercey on a regular basis (Thanks), but have only used it with a wildcard at the end as in
    (DelPageSetup "11×17*")
    not at the beginning. How many different prefixes do you have for "_COLOR*"? You must use a lot more Page Setups than me.
    2011-09
    308
    We have a lot. Trying to remedy that.
    I tried with no * at the beginning. No dice. Same error.
    Thanks!
    6,420
    It should have been loaded by vl-load-com. I would try restarting AutoCAD and testing again.
    LinkedIn
    Tallahassee, FL USA
    3,667
    Not sure if it helps as it looks the same to me, but this has always worked great:
    ; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/purge-all-page-setup-names/m-p/830018#M55676
    (defun DelPageSetup ( Name / Cfgs) ; by Jason Piercey - Autodesk Discussion Forum Moderator
      (setq Cfgs
      (cond
    	  (vlax-for x Cfgs
    		  (vla-delete x)
    	(T
    	  (vl-catch-all-apply
    ;; (DelPageSetup "*") to run or
    ;; (or DelPageSetup (load "DelPageSetup.lsp"))(DelPageSetup "*") to load if needed then run
    To import an 11×17 layout deleting any existing Page Setups beginning with "11×17" and importing Page Setups "11×17" & "11×17 PDF" I use the macro:
    ^C^C^P(DelPageSetup "11×17*")(Steal (strcat (vl-filename-directory (getenv "QnewTemplate")) (chr 92) "AutoCAD Template" (chr 92) "Templates.dwt") (list (list "Page Setups" (list "11×17" "11×17 PDF"))))(Steal (strcat (vl-filename-directory (getenv "QnewTemplate")) (chr 92) "AutoCAD Template" (chr 92) "Templates.dwt") (list (list "Layouts" (list "11×17")))) .regen
    I lean heavily on Lee Mac's Steal from Drawing code and others. While I've written a bit myself I don't feel the need to rewrite code others have already shared online.
    2011-09
    308
    Thanks all, I'm now using DelPageSetup by Jason Piercey and it's working like a charm.
  1. 2016: Page Setup Manager/Page Setups not importing
    By tbevis730888 in forum AutoCAD General
    Last Post: 2016-07-02, 03:49 PM
  2. Delete and Delete All Page Setups
    Last Post: 2015-12-17, 06:38 AM
  3. Replies: 2
    Last Post: 2006-08-11, 12:35 PM
  4. Page setups not working for other users
    By ymarchitect49216 in forum AutoCAD Plotting
    Last Post: 2006-04-01, 08:58 AM
  5. Importing a layout also imports the named page setups
    By jpaulsen in forum AutoCAD Wish List
    Last Post: 2005-02-17, 04:29 AM
