Thread: DWG Trueview Association Window
    2013-05
    Australia
    14
    Default DWG Trueview Association Window
    Hi All,
    When you start DWG Trueview for the very first time, it pops up a "DWG Association" window giving you 4 options relating to using Trueview as your default drawing viewer (see attached screenshot).
    QUESTION: How do I get this window to pop up again, so I can change to another option..?
    I'd like to think there is a simple answer, but I just can't find it.
    It's bothering me because it now means that every time I use Trueview, I have to re-associate AutoCAD back to my default. (BTW, I'm using Trueview 2020). I am aware that closing and opening AutoCAD will re-associate it, but I don't want to have to do that mid-way thru the day just for that purpose.
    T.I.A...
    9,779
    Default Re: DWG Trueview Association Window
    IDK. I just read your last sentence again, so I guess the way that Autodesk has designed this to work is not for you: AutoCAD DWG Launcher.
    I suppose you could hard-code DWG files to launch with whatever version you want.
  1. Lost DWG icon association in 2012
    By Michael J in forum AutoCAD General
    Last Post: 2014-02-10, 10:38 PM
  2. Xref to DWG Association (dependency)
    By CMC in forum AutoCAD General
    Last Post: 2012-01-18, 01:45 PM
  3. dwg file association problem
    By btrusty in forum AutoCAD General
    Last Post: 2009-06-26, 07:11 PM
  4. DWG TrueView for AutoCAD 2008 DWG files
    By Mike.Perry in forum DWG TrueView - General
    Last Post: 2007-03-26, 03:09 AM
  5. DWG TrueView with support for the DWG 2007 file
    By jimmy.bergmark in forum DWG TrueView - General
    Last Post: 2006-04-13, 09:10 PM
