Thread: graphically illustrate Departments
    2004-06
    335
    Default graphically illustrate Departments
    Revit has rooms. Rooms have a parameter called Department. Is there a way to graphically illustrate Departments and tag them? If this can't be done with departments then is there some other suitable Revit way of doing this?
    2002-09
    Madison, WI
    5,688
    Default Re: graphically illustrate Departments
    Create a color scheme. Have the Color scheme associated to the Department parameter. Apply the color scheme to the view.
    2004-06
    335
    Quote Originally Posted by david_peterson View Post
    Yes, that's a great way to color code rooms by department, however I need to be able to tag them by department and have their gross areas tabulated. I know that the area plan can do this, but I was hoping to add something to my current view rather than creating a new view dedicated to that use.
    2002-09
    Madison, WI
    5,688
    Global Parameter applied to a detail component that lists the result?
    Or do a schedule by floor and by department and place them over the area on the view?
    Just some thoughts.
  1. 2015: Gross/Net area scheduling for departments
    By Spark Yunker in forum Revit Architecture - General
    Last Post: 2014-10-07, 08:47 PM
  2. Graphically Select Null Structures
    Last Post: 2012-07-08, 03:48 PM
  3. Removal of Departments from room assignments
    By thillhouse in forum Revit Architecture - General
    Last Post: 2011-08-26, 02:34 PM
  4. colour fill and departments
    By Max Lloyd in forum Revit Architecture - General
    Last Post: 2005-05-11, 12:43 PM
