Hi All,
I am trying to visualize the Oracle Spatial 10g data into the Autodesk Map 3D 2005. As I don’t know much about Autodesk Map so I have little confusion if you could help me in this matter, I’ll be thank full.
1) from where I can get the information about these tables and their structures and is these necessary to be in oracle to access database “ADMPFEATURELAYER, ADMPIMPORTSETTINGS, ADMPLOCKDATA, ADMPME TADATA, ADMPOPTIONS, ADMPOSEMETADATA”. And is that necessary to have these tables in the oracle database because I have tried without this but just now I have seen that these tables are mentioned at few places and looks
necessary.
2) Can u tell me the detailed structure of these tables?
3) How to visualize the spatial data into Autodesk Map 3D 2005.
4) I have defined the spatial tables into the schema but I cannot connect Autodesk Map with them its giving error message that schema is not valid for Autodesk Map so how can I use them here.
I’ll be looking forward to your reply as I am really in need of this. Thanks in advance.
Best Regards,
Adnan Younas.
