Results 1 to 10 of 10
Thread: Append AutoCAD search file path list
    2011-09
    308
    Default Append AutoCAD search file path list
    Hiya gang,
    I've got this really useful lisp from Lee Mac's site that appends additional paths to your AutoCAD search path list.
    It works fine except that I can't seem to add a root drive letter (in this case R:\).
    It adds "R:\Slides", "R:\Fonts", and "R:\Patterns" just fine, but not "R:"
    I'm stumped. Hoping you can help.
    ;;; Adds folders to support path
    (defun LM:sfsp+ ( lst )
        (   (lambda ( str lst )
                (if (setq lst
                        (vl-remove-if
                           '(lambda ( x )
                                (or (vl-string-search (strcase x) (strcase str))
                                    (not (findfile x))
                            lst
                    (setenv "ACAD" (strcat str ";" (apply 'strcat (mapcar '(lambda ( x ) (strcat x ";")) lst))))
            (vl-string-right-trim ";" (getenv "ACAD"))
            (mapcar '(lambda ( x ) (vl-string-right-trim "\\" (vl-string-translate "/" "\\" x))) lst)
    (LM:sfsp+ '("R:\\" "R:\\Slides" "R:\\Fonts" "R:\\Patterns"))
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Re: Append AutoCAD search file path list
    I actually use a modified version of Lee's lisp that substitutes individual user names in added folders as needed, it works well for our needs.
    (defun AddSupportPath (dir / Cpath Uname) ;http://lee-mac.com/addremovesupportpaths.html
      (setq Cpath (getenv "ACAD") Uname (getenv "Username") dir (vl-string-subst Uname "%Username%" dir))
      (or (vl-string-search dir Cpath) (setenv "ACAD" (strcat Cpath ";" dir)))
      (princ)
    Last edited by Tom Beauford; 2019-05-30 at 11:24 AM. Reason: Mine is actually just a modification of Lee Mac's.
    2011-09
    308
    Thaks Tom, I'll keep bashing away at it and will report if I find anything...
    2011-09
    308
    I just tried:
    (AddSupportPath "G:")
    Note - no slashes.
    It worked fine!
    - - - Updated - - -
    Confirmed, the following code works as expected.
    Thanks for your help!
      (princ)
    (AddSupportPath "R:")
    (AddSupportPath "R:\Slides")
    (AddSupportPath "R:\Fonts")
    (AddSupportPath "R:\Patterns")
    2006-11
    7
    I found that uppercase C: or C:\\ did not work while lowercase c: and c:\\ did work except that I'm not sure I would trust c: to work as a path entry. Another option would be to use c:\\. or C:\\. which both work and have the advantage of not ending the path entry with a \ or a :
    2003-07
    560
    2
    There is a un documented answer say you have c:\myprogs........... etc \lisp \blocks etc etc
    If you make the support path c:\myprogs.. note the double period it says look down the path.
    2001-03
    Tallahassee, FL USA
    3,667
    Quote Originally Posted by BIG-AL View Post
    Oddly Trusted Locations uses a triple period for the same thing. "When TRUSTEDPATHS includes a folder that ends with \... (backslash and three dots), all of its subfolders are also trusted." https://knowledge.autodesk.com/suppo...351AF-htm.html
    2014-04
    I haven't tried this yet, but was wondering if this truly "adds" to the list or does it replace the list? Thanks.
    2001-03
    Tallahassee, FL USA
    3,667
    Quote Originally Posted by n.moroniti627291 View Post
    First create a new profile in Options on the Profiles tab click [Add to List…], then select it and click [Set Current], click [Apply] then [OK].
    Now if it messes up your new profile's Support File Search Path you can simply [Delete] the new profile.
    Never use code to modify anything in AutoCAD for the first time without a backup copy.
    100 Club matt.worland's Avatar
    2015-12
    Denver, CO USA
    174
    AFAIK, you must capture the original settings, then append to it and replace the original setting.
    This line here accomplishes that.
    So while this does append to the end, it also replaces the entire setting with a new one.
    matt worland
  1. Search path search path caching?
    By Liamnacuac in forum Networks
    Last Post: 2016-05-31, 07:15 PM
  2. Print Spooler File Location or Printer Description File Search Path?
    By archer1684 in forum CAD Management - General
    Last Post: 2011-04-14, 07:13 PM
  3. Replies: 13
    Last Post: 2010-10-05, 03:54 PM
  4. Append Sheet List tables to Excel Spreadsheets
    By jgratton in forum AutoCAD Tables
    Last Post: 2006-06-29, 09:58 PM
