Thread: Can't delete linetype in dwg
    2015-01
    36
    Default Can't delete linetype in dwg
    I have a dwg with a linetype that I can't get rid of. All entities in the dwg are set to linetype ByLayer, I ran SetByLayer with included blocks and no layer is using this linetype. I can't purge this linetype.
    When I run vla-delete on the vla-get-all-linetypes collection, it errors out with "error: Automation Error. Object is referenced by other object(s)"
    If anybody has any idea what could be referencing this linetype, I would greatly appreciate it.
    All AUGI, all the time marko_ribar's Avatar
    2015-10
    Belgrade, Serbia, Europe
    556
    Default Re: Can't delete linetype in dwg
    Try DGNFIX by Alan J. Thompson...
    It's posted at the swamp under Show stuff hidden forum, so you have to be logged to access it and see the code...
    Here is the link :
    https://www.theswamp.org/index.php?t...6490#msg536490
    BTW. The code is simple, but for author rights I don't want to post it here as duplicate...
    HTH., M.R.
    Marko Ribar, d.i.a. (graduated engineer of architecture)
    M.R. on Youtube
  1. Replies: 0
    Last Post: 2018-09-10, 10:03 PM
  2. Can't delete object with delete button
    By gtx in forum AutoCAD General
    Last Post: 2015-02-02, 01:52 AM
  3. Replies: 5
    Last Post: 2013-06-25, 12:40 AM
  4. I'm trying to create a linetype that has 8" in the linetype
    By mikeprentiss in forum AutoCAD Customization
    Last Post: 2006-08-17, 12:11 PM
  5. Extract Linetype information from a custom Linetype
    By H.Hunter in forum AutoCAD Customization
    Last Post: 2006-08-15, 05:27 AM
