Thread: Problems with wcmatch
    2015-01
    43
    Default Problems with wcmatch
    I want to test a 4 character test string where each character can be an upper-case letter or a number.
    (wcmatch "ABCD" "[A-Z#][A-Z#][A-Z#][A-Z#]") returns T as expected
    (wcmatch "aBCD" "[A-Z#][A-Z#][A-Z#][A-Z#]") returns nil as expected
    (wcmatch "1BCD" "[A-Z#][A-Z#][A-Z#][A-Z#]") returns nil for some unknown reason
    I also tried "[A-Z,#][A-Z,#][A-Z,#][A-Z,#]" and "[#A-Z][#A-Z][#A-Z][#A-Z]" but these didn't work either.
    Can anybody tell me what I'm doing wrong?
    Any help is greatly appreciated.
    2009-11
    5,719
    Default Re: Problems with wcmatch
    (defun c:FOO (/ _match)
      (defun _match (string)
        (or
          (wcmatch string "[A-Z][A-Z][A-Z][A-Z]")                           ; AAAA
          (wcmatch string "#[A-Z][A-Z][A-Z]")                               ; #AAA
          (wcmatch string "[A-Z]#[A-Z][A-Z]")                               ; A#AA
          (wcmatch string "[A-Z][A-Z]#[A-Z]")                               ; AA#A
          (wcmatch string "[A-Z][A-Z][A-Z]#")                               ; AAA#
      (foreach x '("ABCD" "aBCD" "1BCD")
        (prompt (strcat "\n\""
                        x
                        "\" : Match "
                        (if (_match x)
                          "found "
                          "NOT found "
      (princ)
    Computer Specs:
    2018-06
    5
    That code does not meet the OP's conditions.
    There could be more that one numeric digit in the four digit string. The total number of possibilities are 16 combinations, not 5.
    The answer is:
    (wcmatch "ABCD" "[1-Z][1-Z][1-Z][1-Z]")
    2018-06
    5
    A quick revision, check out the ascii table and it will search for the characters 0 to Z except for : to @.
    (defun _match (str)
      (and
        (wcmatch str "[0-Z][0-Z][0-Z][0-Z]")
        (not (wcmatch str "*[:-@]*"))
    Quote Originally Posted by ACE769734 View Post
    The answer is:
    2009-11
    5,719
    (defun _match (str)
      (and
    Well done, Ace.
    Computer Specs:
  1. wildcarding tblobjname BLOCK with wcmatch?
    By mnelson.92099 in forum AutoLISP
    Last Post: 2007-12-12, 07:08 PM
  2. Problems with element not showing
    By Chad Smith in forum Revit Architecture - Families
    Last Post: 2007-02-19, 11:59 AM
  3. List of problems after my first big work with Revit
    By overcaffeined1745 in forum Revit Architecture - General
    Last Post: 2004-02-04, 04:43 AM
  4. Curtain wall problems
    By Martin P in forum Revit Architecture - General
    Last Post: 2003-10-01, 09:36 PM
  5. Problems w/ linked drawings
    By BomberAIA in forum Revit Architecture - General
    Last Post: 2003-08-26, 12:54 PM
