Thread: LISP routine skips line 1 of CSV
    2019-06
    Default LISP routine skips line 1 of CSV
    I have a lisp routine that reads points from a CSV file and then adds a block at each point.
    The problem is that this routine keeps skipping the first line of the CSV file.
    Any idea what part of this code is doing that?
    Thank you.
    (defun C:IMPNT2 (/ str:list read:block a b c cm d s)
      (defun str:list (str / b)
        (foreach x (reverse (vl-string->list str))
          (cond ((eq x 44) (setq b (cons (list x) b)))
    	    (t
    	     (if (not b)
    	       (setq b (cons (cons x (car b)) (cdr b)))
        (mapcar '(lambda (x) (vl-list->string (vl-remove 44 x))) b)
      (defun read:block (s / e f)
        (while (not f)
          (if (setq e (entsel s))
    	(cond
    	  ((wcmatch (cdr (assoc 0 (entget (car e)))) "INSERT")
    	   (setq f t)
    	  (t (alert "Please select BLOCK object."))
    	(alert "Nothing selected, please try again.")
        (vlax-ename->vla-object (car e))
      (if (not SR:PATH)
        (setq SR:PATH (getvar "dwgprefix"))
      (if
        (and (setq
    	   a (getfiled "Select CSV File" SR:PATH "csv" 16)
    	 (setq SR:PATH (strcat (vl-filename-directory a) ""))
    	 (setq a (open a))
    	 (setq c (while	(setq b (read-line a))
    		   (setq c (cons (str:list b) c))
    	 (setq s (read:block "\nSelect Source Block : "))
         (progn
           (close a)
           (setq cm (getvar 'cmdecho))
           (setvar 'cmdecho 0)
           (setq d (ssadd))
           (foreach	x (cdr (reverse c))
    	 (if (and (> (length x) 1)
    		  (numberp (read (cadr x)))
    		  (numberp (read (caddr x)))
    		  (numberp (read (cadddr x)))
    		  (setq	bk (SR:INBLOCK
    			     (list (* (atof (cadr x)) 1000.)
    				   (* (atof (caddr x)) 1000.)
    				   (* (atof (cadddr x)) 1000.)
    			     (vla-get-effectivename s)
    	   (ssadd (vlax-vla-object->ename bk) d)
           (command "_.zoom" "_o" d "")
           (setvar 'cmdecho cm)
           (sssetfirst nil d)
    (SETQ SR:ACAD  (VLAX-GET-ACAD-OBJECT)
          SR:ACDOC (VLA-GET-ACTIVEDOCUMENT SR:ACAD)
          SR:MODEL (VLA-GET-MODELSPACE SR:ACDOC)
    (DEFUN SR:INBLOCK (POINT BLOCKNAME XSCALE YSCALE ZSCALE ROTATION)
      (VLA-INSERTBLOCK
        SR:MODEL
        (VLAX-3D-POINT POINT)
        BLOCKNAME
        XSCALE
        YSCALE
        ZSCALE
        ROTATION
    (VL-LOAD-COM)
    (PRINC)
    (PRINC
      (STRCAT
        "\n:: Import Point Data.lsp ::"
        "\n:: Created by Satish Rajdev | "
        (MENUCMD "M=$(edtime,$(getvar,date),DDDD"," D MONTH YYYY)"
        "\n:: Type "IMPNT" to Import CSV ::"
    (PRINC)
    5,719
    Default Re: LISP routine skips line 1 of CSV
    Consider your use of CDR here:
    ;;<snip>
    ;;<snip>
    2019-06
    CDR is already in that line of code.
    Do you mean remove it??
    5,719
    Quote Originally Posted by mdumais24782845 View Post
    The top line of a CSV often represents the column headers only, so skipping the first line using CDR makes sense, if that is the format of your CSV files.
    However, you're wanting to include the first line of the CSV file you've selected, indicating that is not the format of the CSV file you're attempting to cull... Therefore consider your usage of CDR.
    Cheers
  1. Lisp routine in a Lisp routine
    By jayhay35365091 in forum AutoLISP
    Last Post: 2013-10-09, 02:30 PM
  2. Run Lisp Routine From Another Lisp Routine
    By mwilson in forum AutoLISP
    Last Post: 2013-07-25, 02:46 PM
  3. 2011: Express Tools Auto Number - Skips Number in Multi-line Mtext
    By stusic in forum AutoCAD General
    Last Post: 2013-01-29, 02:38 PM
  4. Revision schedule skips a line
    By matt__w in forum Revit MEP - General
    Last Post: 2010-01-07, 04:26 PM
