Thread: Modify code help
    I could stop if I wanted to cadd4la's Avatar
    2001-12
    Newport Beach, CA
    399
    Default Modify code help
    Hello everyone,
    I need help to modify this code so it will run continuously. The code now runs were if I have two or more areas that I need to divide the same distance, I have to start the code, pick one of the areas, and then hit enter, then start the code again. I would like to just be able to pick all the areas one after another and it divide them separate.
    Thanks as always.
    (DEFUN C:DIV2()(SETVAR "CMDECHO" 0)
    (SETQ	SS1   (SSGET); Get selection set.
    );_End SETQ
    (COMMAND "DIVIDE" SS1 "2")
    (SETVAR "CMDECHO" 1)
    Tallahassee, FL USA
    3,667
    Default Re: Modify code help
    The DIVIDE (Command) creates evenly spaced point objects or blocks along the length or perimeter of an object.
    http://help.autodesk.com/view/ACD/20...3-49EB6378335C
    It doesn't divide areas.
    2001-12
    Newport Beach, CA
    399
    Tom,
    Thank you for your input and you are right, but I looking for my code to run continuously until I hit escape.
    Cadd4la
    5,719
    Your code with a While loop:
    (defun c:DIV2 (/ ss)
      (setvar 'cmdecho 0)
      (while (setq ss (ssget ":S:E:L"))
        (command "._divide" ss 2)
      (setvar 'cmdecho 1)
    DIVIDE Command only acts on the first entity in the selection set, so I added a selection filter as well.
    Tallahassee, FL USA
    3,667
    About Special Control Characters in Command Macros: http://help.autodesk.com/view/ACD/20...A-BEAEBA83A424
    * Repeats a command until another command is started or the current command is ended.
    Try just adding an asterisk in front of the macro, here's an example: https://forums.autodesk.com/t5/autoc...t/td-p/1996743
    2001-12
    Newport Beach, CA
    399
    Blackbox,
    It works great, thank you for your help.
    Cadd4la
  1. Adding modify data to dxf code
    By mvsawyer in forum AutoLISP
    Last Post: 2015-07-17, 06:46 PM
  2. Allow Other Code Compilers for ARX Code
    Last Post: 2013-02-10, 08:06 AM
  3. Modify Floors > Modify Sub Elements
    By diesellam in forum Revit Architecture - General
    Last Post: 2010-02-23, 01:53 PM
  4. Insert vbscript code has not code
    By buzz in forum AMEP General
    Last Post: 2008-02-09, 03:08 AM
  5. Convert VBA code to VB code
    By Robert Platt in forum VBA/COM Interop
    Last Post: 2007-08-15, 10:13 PM
