Thread: Modify code help
    I could stop if I wanted to cadd4la's Avatar
    2001-12
    Newport Beach, CA
    351
    Default Modify code help
    Hello everyone,
    I need help to modify this code so it will run continuously. The code now runs were if I have two or more areas that I need to divide the same distance, I have to start the code, pick one of the areas, and then hit enter, then start the code again. I would like to just be able to pick all the areas one after another and it divide them separate.
    Thanks as always.
    (DEFUN C:DIV2()(SETVAR "CMDECHO" 0)
    (SETQ	SS1   (SSGET); Get selection set.
    );_End SETQ
    (COMMAND "DIVIDE" SS1 "2")
    (SETVAR "CMDECHO" 1)
    AutoCAD 2010 Windows7 Ultimate
    _________________________________________________________
    My spelling is wobbly. It's good spelling but it wobbles and the letters get in the wrong places.
    ... Winnie the Pooh
    Tallahassee, FL
    3,181
    Default Re: Modify code help
    The DIVIDE (Command) creates evenly spaced point objects or blocks along the length or perimeter of an object.
    http://help.autodesk.com/view/ACD/20...3-49EB6378335C
    It doesn't divide areas.
    Tom Beauford P.S.M. - Civil 2019 on Windows 10 Enterprise
    Ph# (850)606-1516 Home Page
    2001-12
    Newport Beach, CA
    351
    Tom,
    Thank you for your input and you are right, but I looking for my code to run continuously until I hit escape.
    Cadd4la
    ... Winnie the Pooh
    Programming Moderator BlackBox's Avatar
    5,466
    Your code with a While loop:
    (defun c:DIV2 (/ ss)
      (setvar 'cmdecho 0)
      (while (setq ss (ssget ":S:E:L"))
        (command "._divide" ss 2)
      (setvar 'cmdecho 1)
    DIVIDE Command only acts on the first entity in the selection set, so I added a selection filter as well.
    Tallahassee, FL
    3,181
    About Special Control Characters in Command Macros: http://help.autodesk.com/view/ACD/20...A-BEAEBA83A424
    * Repeats a command until another command is started or the current command is ended.
    Try just adding an asterisk in front of the macro, here's an example: https://forums.autodesk.com/t5/autoc...t/td-p/1996743
    2001-12
    Newport Beach, CA
    351
    Blackbox,
    It works great, thank you for your help.
    Cadd4la
    ... Winnie the Pooh
  1. Adding modify data to dxf code
    By mvsawyer in forum AutoLISP
    Last Post: 2015-07-17, 06:46 PM
  2. Allow Other Code Compilers for ARX Code
    By IanR in forum AutoCAD Wish List
    Last Post: 2013-02-10, 08:06 AM
  3. Modify Floors > Modify Sub Elements
    By diesellam in forum Revit Architecture - General
    Last Post: 2010-02-23, 01:53 PM
  4. Insert vbscript code has not code
    By buzz in forum AMEP General
    Last Post: 2008-02-09, 03:08 AM
  5. Convert VBA code to VB code
    By Robert Platt in forum VBA/COM Interop
    Last Post: 2007-08-15, 10:13 PM
