Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: This is driving me MAD
  1. #21
    Tallahassee, FL
    3,165
    Default Re: This is driving me MAD
    Quote Originally Posted by aaronic_abacus View Post
    works fine in 2000, not a coding error
    vl huh?
    still no luck.
    if I can't write to the files how will programs load automatically, i'm just trying to AUTOLOAD a string
    Just to be clear there has never been a time when it was OK to modify the acad<release>.lsp file. Acad.lsp, acaddoc.lsp, and acad.rx have been the user created files set up for this purpose by AutoCAD you should have been using in 2000 as well. Now that AutoCAD and most organizations IT policies have blocked you completely it's time to do this the way you should have been doing it all these years. If
    (findfile "acaddoc.lsp")
    returns nil create one in the
    (getenv "userprofile")
    folder where permissions shouldn't be a problem. Appending your code after the last line will display whatever your code sends last as well as any errors it may generate.
    Tom Beauford P.S.M. - Civil 2019 on Windows 10 Enterprise
    Ph# (850)606-1516 Home Page
  2. #22
    I could stop if I wanted to aaronic_abacus's Avatar
    2006-04
    398
    so there's no automatically loading file I can write to?
    http://www.watsonlisp.com
    Artificial Intelligence for AutoCAD
    Find detail drawings by text and attribute content!
    6000 lines of code and and in development since 1997.
  3. #23
    Programming Moderator BlackBox's Avatar
    5,454
    <Comment removed, NSFW... Link an image that conveys same>
  4. #24
    Tallahassee, FL
    3,165
    Is there an issue with using the acaddoc.lsp file designed to be created and modified by us just for this purpose?
    Are we missing something?
  5. #25
    2006-04
    398
    could someone test this for autocad2011 or down?
    please confirm if it is writing to acaddoc.lsp
    (DEFUN C:AUTOLOAD ()
    (PRINC)
    (PROMPT "\n*AUTOLOAD WATSON SETUP* ")
    (SETQ PGPF NIL)
    (SETQ PGPFF NIL)
    (SETQ PGPLN "(LOAD \"Wat.lsp\")" )
    (SETQ PGPFN (FINDFILE "ACAD2000.lsp" ))
    (IF (/= PGPFN NIL)
     (PROGN
      (SETQ PGPFNL (STRLEN PGPFN))
      (SETQ PGPFN2 (SUBSTR PGPFN 1 (- PGPFNL 12)))
      (SETQ PGPFN2 (STRCAT PGPFN2 "acaddoc.lsp"))
      (SETQ PGPF (OPEN PGPFN2 "a"))
      (WRITE-LINE " " PGPF)
      (WRITE-LINE PGPLN PGPF)
      (IF (/= PGPF NIL)
       (PROGN
        (CLOSE PGPF)
        (PROMPT "\nWat.lsp added to ")
        (PROMPT PGPFN2)
        (SETQ PGPFF 1)
       ); END PROGN PGPF
       (PROGN
        (PROMPT "\n CANNOT WRITE TO ")
        (PROMPT PGPFN2)
      ));END PROGN /IF PGPF
    ));END PROGN/IF PGPFN
    (SETQ PGPFN (FINDFILE "ACAD2001.lsp" ))
    (IF (/= PGPFN NIL)
     (PROGN
      (IF (/= PGPF NIL)
       (PROGN
        (CLOSE PGPF)
        (PROMPT PGPFN2)
        (SETQ PGPFF 1)
       ); END PROGN PGPF
       (PROGN
        (PROMPT PGPFN2)
      ));END PROGN PGPF
    (SETQ PGPFN (FINDFILE "acad2002.lsp" ))
    (IF (/= PGPFN NIL)
     (PROGN
      (IF (/= PGPF NIL)
       (PROGN
        (CLOSE PGPF)
        (PROMPT PGPFN2)
        (SETQ PGPFF 1)
       ); END PROGN PGPF
       (PROGN
        (PROMPT PGPFN2)
      ));END PROGN PGPF
    (SETQ PGPFN (FINDFILE "ACAD2003.lsp" ))
    (IF (/= PGPFN NIL)
     (PROGN
      (IF (/= PGPF NIL)
       (PROGN
        (CLOSE PGPF)
        (PROMPT PGPFN2)
        (SETQ PGPFF 1)
       ); END PROGN PGPF
       (PROGN
        (PROMPT PGPFN2)
      ));END PROGN PGPF
    (SETQ PGPFN (FINDFILE "ACAD2004.lsp" ))
    (IF (/= PGPFN NIL)
     (PROGN
      (IF (/= PGPF NIL)
       (PROGN
        (CLOSE PGPF)
        (PROMPT PGPFN2)
        (SETQ PGPFF 1)
       ); END PROGN PGPF
       (PROGN
        (PROMPT PGPFN2)
      ));END PROGN PGPF
    (SETQ PGPFN (FINDFILE "ACAD2005.lsp" ))
    (IF (/= PGPFN NIL)
     (PROGN
      (IF (/= PGPF NIL)
       (PROGN
        (CLOSE PGPF)
        (PROMPT PGPFN2)
        (SETQ PGPFF 1)
       ); END PROGN PGPF
       (PROGN
        (PROMPT PGPFN2)
      ));END PROGN PGPF
    (SETQ PGPFN (FINDFILE "ACAD2006.lsp" ))
    (IF (/= PGPFN NIL)
     (PROGN
      (IF (/= PGPF NIL)
       (PROGN
        (CLOSE PGPF)
        (PROMPT PGPFN2)
        (SETQ PGPFF 1)
       ); END PROGN PGPF
       (PROGN
        (PROMPT PGPFN2)
      ));END PROGN PGPF
    (SETQ PGPFN (FINDFILE "ACAD2007.lsp" ))
    (IF (/= PGPFN NIL)
     (PROGN
      (IF (/= PGPF NIL)
       (PROGN
        (CLOSE PGPF)
        (PROMPT PGPFN2)
        (SETQ PGPFF 1)
       ); END PROGN PGPF
       (PROGN
        (PROMPT PGPFN2)
      ));END PROGN PGPF
    (SETQ PGPFN (FINDFILE "ACAD2008.lsp" ))
    (IF (/= PGPFN NIL)
     (PROGN
      (IF (/= PGPF NIL)
       (PROGN
        (CLOSE PGPF)
        (PROMPT PGPFN2)
        (SETQ PGPFF 1)
       ); END PROGN PGPF
       (PROGN
        (PROMPT PGPFN2)
      ));END PROGN PGPF
    (SETQ PGPFN (FINDFILE "ACAD2009.lsp" ))
    (IF (/= PGPFN NIL)
     (PROGN
      (IF (/= PGPF NIL)
       (PROGN
        (CLOSE PGPF)
        (PROMPT PGPFN2)
        (SETQ PGPFF 1)
       ); END PROGN PGPF
       (PROGN
        (PROMPT PGPFN2)
      ));END PROGN PGPF
    (SETQ PGPFN (FINDFILE "ACAD2010.lsp" ))
    (IF (/= PGPFN NIL)
     (PROGN
      (IF (/= PGPF NIL)
       (PROGN
        (CLOSE PGPF)
        (PROMPT PGPFN2)
        (SETQ PGPFF 1)
       ); END PROGN PGPF
       (PROGN
        (PROMPT PGPFN2)
      ));END PROGN PGPF
    (SETQ PGPFN (FINDFILE "ACAD2011.lsp" ))
    (IF (/= PGPFN NIL)
     (PROGN
      (IF (/= PGPF NIL)
       (PROGN
        (CLOSE PGPF)
        (PROMPT PGPFN2)
        (SETQ PGPFF 1)
       ); END PROGN PGPF
       (PROGN
        (PROMPT PGPFN2)
      ));END PROGN PGPF
    (IF (= PGPFF NIL) (SETQ PGPFN (GETFILED "FIND AN AUTOMATICALLY LOADING LISP FILE" "" "LSP" 2)))
    (IF (/= PGPFN NIL)
     (PROGN
      (SETQ PGPF (OPEN PGPFN "a"))
      (IF (/= PGPF NIL)
       (PROGN
        (CLOSE PGPF)
        (PROMPT PGPFN)
        (SETQ PGPFF 1)
       ); END PROGN PGPF
       (PROGN
        (PROMPT PGPFN)
      ));END PROGN PGPF
    (PRINC)
    ); END AUTOLOAD
  1. Insulation Detail Component Causes Snaps To Go Mad!
    By gdaniels in forum ACA General
    Last Post: 2005-11-15, 01:01 PM
