cross sections from points without surface
Summary: Simple point data cross sections without the need for a surface
Description: We do a lot of river bar cross section monitoring where the data is not sufficient to create a surface. Would like to be able to create cross sections without needing to create a bogus surface!
Product and Feature: AutoCAD Civil 3D - Cross Sections
Submitted By: pool362409 on 06/14/2019
Re: cross sections from points without surface
We do the same. We simply make a feature line out of a 3dpolyline connecting the points then offset the line 5' each side. It's not perfect but its relatively quick and easy.
- You may not post replies
- You may not edit your posts
Forum Rules
