Results 1 to 7 of 7
Thread: Drawing Units - Lisp
    2004-06
    Oklahoma
    19
    Default Drawing Units - Lisp
    Let me start off by saying that I know absolutely nothing about writing lisps or code.
    I need a simple (LOL) lisp that will open the drawing units dialog box, set the type to engineering, set the precision to 0'-0.00000", set the angle type to decimal degrees, set the angle precision to 0.00, set insertion scale to inches and finally set the lighting units to American.
    How difficult would this be to create?
    AutoCAD 2016 & up
    Thanks for any & all help
    Mike
    2003-07
    560
    Default Re: Drawing Units - Lisp
    about this hard
    look into insunits & lightingunits
    (defun civ_units ()
    (SETQ ANGBASEE (GETVAR "ANGBASE"))
    (SETQ ANGDIRR (GETVAR "ANGDIR"))
    (SETQ LUNITSS (GETVAR "LUNITS"))
    (SETQ LUPRECC (GETVAR "LUPREC"))
    (SETQ AUNITSS (GETVAR "AUNITS"))
    (SETQ AUPRECC (GETVAR "AUPREC"))
    (SETVAR "LUNITS" 2)
    (SETVAR "ANGBASE" 0.0)
    (SETVAR "ANGDIR" 0)
    (SETVAR "LUPREC" 0)
    (SETVAR "AUNITS" 0)
    (SETVAR "AUPREC" 0)
    (defun old_civ_units ()
    (SETVAR "LUNITS" lunitss)
    (SETVAR "ANGBASE" angbasee)
    (SETVAR "ANGDIR" angdirr)
    (SETVAR "LUPREC" luprecc)
    (SETVAR "AUNITS" aunitss)
    (SETVAR "AUPREC" auprecc)
    AUGI Addict madcadder's Avatar
    Too far from the beach
    1,054
    Mike,
    If you take Big Al's code and change it to
    (defun c:civ_units (/)
    then you can type it in at the command and set it when you want (or reset it)
    Quote Originally Posted by BIG-AL View Post
    about this hard
    (defun civ_units ()
    (SETVAR "LUNITS" 2)
    (SETVAR "ANGDIR" 0)
    (SETVAR "LUPREC" 0)
    (SETVAR "AUNITS" 0)
    (SETVAR "AUPREC" 0)
    2004-06
    Oklahoma
    19
    Awesome! Thank you
    2004-06
    Oklahoma
    19
    Not getting the results I was hoping for. See screenshot of what I am trying to achieve with the lisp.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Set INSUNITS to 1 for inches
    Set LIGHTINGUNITS to 1 for American
    2004-06
    Oklahoma
    19
    With a little bit of trial and error, I was able to get my lisp work.
    (SETQ LIGHTINGUNITS (GETVAR "LIGHTINGUNITS"))
    (SETQ INSUNITS (GETVAR "INSUNITS"))
    (SETVAR "LUNITS" 3)
    (SETVAR "ANGDIR" 0)
    (SETVAR "LUPREC" 5)
    (SETVAR "AUNITS" 0)
    (SETVAR "AUPREC" 2)
    (SETVAR "LIGHTINGUNITS" 1)
    (SETVAR "INSUNITS" 1)
    (SETVAR "LIGHTINGUNITS" lightingunits)
    (SETVAR "INSUNITS" insunits)
    Thanks again for your guidance.
  1. More Units, more units, more units, more units
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2014-10-27, 01:47 PM
  2. Replies: 4
    Last Post: 2007-12-10, 07:03 PM
  3. Replies: 12
    Last Post: 2006-12-14, 09:04 PM
  4. Convert Civil drawings using decimal units into Arch. units
    By tlarocco in forum AutoCAD Civil 3D - General
    Last Post: 2006-07-17, 05:52 PM
