Thread: Using "IF, THEN" expression for Sheet Metal Thickness call out.
    2012-12
    7
    Default Using "IF, THEN" expression for Sheet Metal Thickness call out.
    I am trying to find an ilogic formula or some other alternative to change the sheet metal "thickness" (0.1345) to read "10GA" automatically in my parts list. It is quite useful to have the "thickness" auto populate in the parts list, but fabricators would rather see guage material called out.
    Thanks in advance.
    Scott
    2012-12
    7
    Default Re: Using "IF, THEN" expression for Sheet Metal Thickness call out.
    figured it out. thanks everyone.
    Turlock, CA
    6,397
    Glad you figured it out. Can you post your solution for others that may have a similar issue?
    C:> ED WORKING....
    2012-12
    7
    Actually, it is the simplest dang thing...
    use: = <Sheet Metal Rule>
    in the parts list add "Stock Number" to the column desired.
    see the video attached...
    https://autode.sk/2YCq2jS
    - - - Updated - - -
    https://knowledge.autodesk.com/commu...a-a20f0662c493
    - - - Updated - - -
    its not letting me upload video.
    So, in your part just add "=<Sheet Metal Rule>" in the iproperty "Stock Number". The sheet metal rule should be assigned 16GA, 12GA etc...
    Turlock, CA
    6,397
    Thanks for the update. For video, usually its just a link to youtube, vimeo, etc. If you want to upload a file, the file uploader tells you what extensions are allowed. If its not on the list, zip it. Files size matters too.
    C:> ED WORKING....
  1. Replies: 0
    Last Post: 2015-08-07, 05:34 PM
  2. Replies: 0
    Last Post: 2014-12-01, 03:49 AM
  3. Sheet Metal Thickness as Template Parameter
    Last Post: 2013-12-04, 03:05 PM
  4. Copy & utilize sheet metal rules on Derived & Mirrored sheet metal parts
    Last Post: 2012-10-18, 12:40 PM
  5. Replies: 4
    Last Post: 2009-07-29, 09:43 PM
Tags for this Thread
