Thread: FastSel with an Attribute Copy/Past Command
    2019-06
    Default FastSel with an Attribute Copy/Past Command
    Hi all,
    For context, I am trying to create electrical schematics where attributes of blocks can be copied onto select blocks that are intersecting them (as if they are connected on a schematic). The idea being that I can have a switchboard reference copied onto the circuit breaker connected to it.
    I am trying to run FastSelect and nest in an attribute copy command within it. The problem is, I don't wish for user interaction - FastSelect requires user prompting and I also would like it to cycle through every named block instance so it automatically does it for the entire workspace.
    I am using the following code for cycling through my blocks:
    (vl-load-com)
    (defun C:SELBLKN ( / e ss objs blk) ; by name
      (setq e (getstring T "\nType block name(s) to select (comma-delimited list or wildcards): ")
            objs (ssadd))
      (if (setq ss (ssget "_X" '((0 . "INSERT"))))
        (progn
          (repeat (setq i (sslength ss))
            (setq name (strcase (vla-get-effectivename (vlax-ename->vla-object (setq blk (ssname ss (setq i (1- i))))))))
            (if (wcmatch name (strcase e))
              (ssadd blk objs)))
        (if (zerop (getvar "CMDACTIVE"))
          (progn (sssetfirst nil objs)
            (princ "Use 'P' for this selection set: ")(princ))
          objs)))
    (princ "\nSELBLKN commands loaded.")(princ)
    And the following for copying attributes:
    (defun c:CAttribTag ( / att tag str blk a )
      (vl-load-com)
      (setq att (nentsel "\nPick attribute..."))
      (setq tag (vla-get-tagstring (vlax-ename->vla-object att)))
      (setq str (vla-get-textstring (vlax-ename->vla-object att)))
      (while (setq blk (car (entsel "\nPick block to paste attribute value to - ENTER TO FINISH...")))
        (setq a blk)
        (while (= (cdr (assoc 0 (entget (setq a (entnext a))))) "CABLEREF")
          (if (= (strcase tag) (strcase (vla-get-tagstring (vlax-ename->vla-object a))))
            (vla-put-textstring (vlax-ename->vla-object a) str)
    Understandably it is a hard ask, but is anyone able to assist me with combining these functionalities/able to point me in the right direction for easy fast-select integration?
    Cheers for all of your help
    Hugh
    CORDOBA-ARGENTINA
    275
    Default Re: FastSel with an Attribute Copy/Past Command
    Please upload the sample.dwg you want to apply it.
  1. Copy & Past Tables
    Last Post: 2013-11-17, 10:09 PM
  2. Replies: 0
    Last Post: 2011-09-23, 07:21 PM
  3. USE MOVE,COPY,ROTATE,SCALE COMMAND IN ONE COMMAND
    By cadsoft in forum AutoCAD Tips & Tricks
    Last Post: 2011-03-14, 02:47 PM
  4. Copy previous Block Attribute Value to next Block Attribute
    By CADfunk MC in forum VBA/COM Interop
    Last Post: 2009-02-27, 09:46 PM
