Thread: An alignment offset label that picks up the surface elevation as well?
    2016-04
    California
    150
    Default An alignment offset label that picks up the surface elevation as well?
    Hello all.
    I ran into a situation where I needed a alignment offset label that also included the surface elevation of the surface I was using. Since this is not a standard label I thought I would create one, but the program does not seem to allow a surface elevation in the offset label. I can do separate labels but I want them combined into one label for sheet space reasons. Anyone know of a way?
    TT
    2013-11
    36
    Default Re: An alignment offset label that picks up the surface elevation as well?
    Add reference text to it. You'll find it in the "A+" drop-down button just to the right of the Component in the style dialog.
    Select "Surface", and you'll get many of the options that surfaces provide.
  1. 2011: label points at an offset from alignment showing stat, offset, and description
    By mw156 in forum AutoCAD Civil 3D - Survey
    Last Post: 2016-09-29, 06:10 PM
  2. Multiple picks
    Last Post: 2014-11-14, 11:09 PM
  3. grips- no multiple picks
    By gdonovan in forum AutoCAD General
    Last Post: 2005-01-12, 10:49 PM
  4. roof construction picks columns
    By rjjlee in forum Revit Architecture - Wish List
    Last Post: 2004-10-18, 11:55 AM
Tags for this Thread
