Results 1 to 6 of 6
Thread: Forcing tangency from arc to line in the pline command
    2016-04
    California
    149
    Default Forcing tangency from arc to line in the pline command
    I am drawing a center line in the middle of an existing road based on a topo. Using the pline (polyline) command I can draw a straight line. Then use the Arc command to draw an arc. That arc is tangent to the straight line. However when I try to draw another straight line from the arc I just drew (using the Line command), it is NOT tangent to the arc I just drew. How do I force tangency for these line segments?
    TT
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,658
    Default Re: Forcing tangency from arc to line in the pline command
    You entered L to switch from arc to line, enter L again for length and enter the tangent length.
    I'd create the tangents first and use the fillet command to create the arcs afterwards though.
    2016-08
    Try This one maybe it will help you.
    - - - Updated - - -
    Sorry the link didn`t appear in my last comment
    search for the following at youtube
    How to create geometry Tangent or Perpendicular FROM an object in Civil 3D ( Jerry Bartels )
    2016-04
    California
    149
    Thanks Tom.
    This works and you don't have to type in a distance you can click a length...and this is better for my case.
    Very good.
    By the way, what are the letters, P.S.M. after your name signify?
    Just curious.
    TT
    2001-03
    Tallahassee, FL USA
    3,658
    Quote Originally Posted by tadthurston725387 View Post
    Thanks Tom.
    Very good.
    Just curious.
    TT
    Florida Professional Surveyor & Mapper, but I've spent most of the past 1/4 century using AutoCAD, Map & Civil 3D.
    2009-11
    5,714
    No need for Polyline during layout (just when creating the Alignment), as CURVEFROMENDOFOBJECT and LINEFROMENDOFOBJECT Commands are your friends.
    Computer Specs:
  1. Arc Tangent to Line or Arc with Osnap
    Last Post: 2014-11-13, 12:07 PM
  2. 2014: constructing an arc tangent to an arc and a line
    By aellsworth in forum AutoCAD Tips & Tricks
    Last Post: 2013-12-19, 08:40 PM
  3. center van arc in Pline
    By clovis in forum AutoLISP
    Last Post: 2008-11-21, 02:56 PM
  4. Draw PLine Arc parallel to existing Arc?
    By norrin in forum AutoCAD General
    Last Post: 2006-02-08, 07:08 PM
  5. Replies: 2
    Last Post: 2005-01-03, 02:57 PM
Tags for this Thread
