Thread: Get PickFirst selection set from AutoLISP
    2015-01
    34
    Default Get PickFirst selection set from AutoLISP
    I'm writing a routine to select a layer from a dcl listbox. If the user has already selected an entity, I want the entity layer to already be selected when the dialog box opens. The only information I can find on the PickFirst SelectionSet is for .NET programming. Is there anyway to access this set in AutoLISP?
    As always, any help is greatly appreciated
    All AUGI, all the time Tharwat's Avatar
    2010-06
    897
    Default Re: Get PickFirst selection set from AutoLISP
    (setq ss (ssget "_I"))
    2015-01
    34
    Thanks for the tip Tharwat, that did the trick. I actually knew about that mode but I don't think I was implementing it correctly. Works perfectly now though!
    Programming Moderator BlackBox's Avatar
    2009-11
    5,451
    FWIW, (ssget) accepts an implied selection if one exists, or prompts for a selection.
    Computer Specs:
    Dell Precision 3620, Core i7-7700K 4.2GHz, 64GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
    2010-06
    897
    Quote Originally Posted by deheylen690271 View Post
    Good to know.
    Happy coding.
  1. 2016: PICKFIRST set to 1 - what else is wrong?
    By Opie in forum AutoCAD General
    Last Post: 2016-05-20, 12:50 PM
  2. 2014: Hatching and PICKFIRST
    By jpcadconsulting347236 in forum AutoCAD General
    Last Post: 2014-02-20, 12:36 AM
  3. Universal PICKFIRST system variable for Noun/Verb selection
    Last Post: 2012-10-01, 03:21 PM
  4. Pickfirst variable problem
    By mrakarees in forum CAD Management - General
    Last Post: 2008-10-08, 05:40 PM
  5. Pickfirst
    By marble in forum AutoCAD General
    Last Post: 2005-03-17, 01:20 PM
